Originally Posted by snoobler
Originally Posted by JRed
Few more miles. Intake plenum has some "stuff" in it already. I'm not sure I remember it accumulating so fast before, but in theory it might have -- the 1NZ-FXE pushes some of the intake charge back into the plenum. In any case, it hasn't burnt a noticeable amount of oil.
Originally Posted by cjolson140
When the car auto-stops the engine, is it sometimes really rough? Almost like it's dieseling a little, or gives a noticeable jerk to the car? My dad's Prius has been burning oil for years and does this often.
Every now and then. I think that could have something to do with residue that builds up in the intake plenum. Take the airbox off and open the throttle body carefully and you'll see a puddle of oil/whatever down there. I just hold the throttle body open with an adjustable wrench on the spring mechanism and use some extra long needle-nose pliers and shop rags to dab it all out.
Clean the throttle plate/throttle body while you're at, and the MAF too. Disconnect the battery for a few seconds and reconnect it.
Originally Posted by atomix8
Looking forward (sort of) to doing this to the 220k mile Prius in a few months. Switching to 15w40 has helped oil consumption as well, looks like lots of posts here about using 15w40 in the Prius with barely any effect (an MPG or two)
My 'parts are barely touching' UOA
https://www.bobistheoilguy.com/foru...veller-15w40-cj-4-sn-6500-mi#Post5255894
I tried running Rotella 15w40, T5 10w-40, T6 5w-40. It drinks everything about the same ... besides Pennzoil Platinum 5w30. It
guzzles that stuff like a 7.3 Powerstroke guzzles diesel pulling a 15,000 lb trailer. No exaggeration -- it burned two full quarts in less than 1000 miles. My WRX had the same habit of drinking PP 5w30, so I'm not surprised.
It's the bolded bit that fixes it. You'll get P319X "low power" or "fail to start" codes due to muck build up on plate/body. Car compensates for it up to a point, but once it exceeds that threshold, rough starts and failed starts are the norm.
Really interested to see how this plays out. I have 6 of these things in the extended family. The PCV valve seems to have helped one a bit, but I'd like to give this a shot if it makes a difference.
Thanks!
350 miles since the soak. Wife and I have both been driving the car harder than usual as a sort of "stress test". I filled the oil as exactly to the full mark as I could, ran the car for a bit, and refilled to full.
The oil level hasn't changed at all so far as I can tell, and it would normally be around 1/4 to 1/3rd of a quart low - an amount that would definitely move the oil off of the full mark on the dipstick.
Don't want to claim it cured the oil burning just yet, but it seems promising. It certainly hasn't made it any worse.
