Glad to hear it's working!UPDATE
Alright, I think I’m ready to declare this a success for my ‘07 Prius as well.
It’s been 500 miles since the soak. Oil consumption is drastically reduced so far. Previous owner states consumption was as bad as 1 qt. per 500 miles in some cases.
With fresh GTX HM 10w-40 after the soak, oil level is down maybe 1/16” in 500 miles.
Before you call 10w-40 “cheating” to reduce consumption, I tried SuperTech 10w-40 before the soak, and 1/2 qt. was gone in 850 miles.
The oil is still very light colored and “new” looking at 500 miles, whereas the oil turned really dark amber to black in just a few miles previously. I know you can’t tell much by how oil “looks” to the naked eye, but this all lines up and makes sense to me, at least.
I’ll try to post an update in the future as well. So far, I’d completely recommend a piston soak if you have a Prius with a drinking problem.
I guess the acid test will be getting back to a 5w-30 synthetic for the cold MT winters.
Oil weight never made a difference in mine before the piston soak. 15w-40, 10w-40, 10w-30, synthetic, blend, dino. Didn't matter, drank 'em all at the same speed. That's why after just 500-1000 miles of driving I knew I'd fixed the problem.
It's such a simple procedure on the Prius it's almost like why not at least try it?
Did yours smoke like crazy when you first started it?
