Edit: Car is 2019 Kia Sportage
What size socket to hand crank the motor? How often should I crank the motor by hand with 2 oz of fluid in the cylinders over a 24hr period?
How do you get the motor to crank with the plugs out? My first and only piston soak, I had plugs out and coils off (disconnected) and when I turned the key ... Nothing but an awful buzzing sound. Everyone else gets a geyser of solvent and gunk shooting out the spark plug holes. What am I doing wrong?
Is it best to drain the oil that the Berryman leaks down into before starting? I've heard of people doing both ways. That is, run the engine with the B12 in the crankcase after soaking (before changing oil) like an improvised flush, and others say to change the oil before the first start after the soak is done.
How to properly lubricate the cylinder walls after soaking? My understanding is that you pour about 1-2oz of motor oil in each hole to coat the cylinder walls so it seals when cranking after the plugs are back in. Do you hand crank it with the oil added to work it in? How long after adding the oil before you can reinstall the plugs and attempt to start it?
All input is welcome and appreciated. Ask me questions to help you help me lol
