My 1991 Acura Integra never used a drop of oil for the 60,000 miles that I had it. Used Mobil 1.
Was it the GSR model with DOHC VTEC? Usually the engines with this setup use oil, not the "lesser" versions.quote:
Always the unknowable answer.... If your engine has a failure of an oil-lubricated part, and if they claim that your failure to follow their recommendations was the cause of the failure, and if they prove that you didn't follow the recommendations or you can't prove that you did...get out your cheque book.quote:
Originally posted by absolude:
BTW,using other than recommended oil weight will void my warranty?
