Green Grease or Lucas Xtra Duty?
West Michigan
I manage a fleet of 10 trucks, I have been using Green Grease for decades on my personal vehicles, ball joints, tie rod ends, u-joints, slip yokes you name it.
I swear by this stuff. But it’s pricy.
So shopping around for a alternative grease for my fleet and personal use.
My trucks go 10k between PM’s, lots of dirt roads, mud, snow, flooded roads, these are delivery trucks. Always fully loaded, ran 7 days a week and in the summer it gets hot, 100+ at times.
In the winter it gets below zero.
Green Grease is full synthetic and holds up superbly well. Does not liquefy, sticks to everything forever.
Should I keep with the Green Grease, or switch to the Lucas, which is about half the cost.
One tube of grease lubes two and a half trucks.
What base is the Green grease? Lithium?, Aluminum?,Bentonite? Better match it unless you want to have compatibility issues.
Why would Lucas be your only alternative?
I have found the LUCAS X-TRA to be the very best under all conditions -- it doesn't wash out, and it doesn't freeze out.
Update-I’ve stuck with the Green Grease, I buy it by the case at NAPA, it’s $100 before my discount.
I have been learning to not over grease my trucks, which is saving grease.
I have a electric grease gun and getting right to the point of not pushing to much old grease out and onto the ground is a learning curve.
Thank you for everyones feedback.
Yesterday (03/08/2024) I called Lucas and had a nice conversation with the head technical service guy. He told me there are a couple key ingredients in thdb
Polyurea. And NOT compatible with any Non-polyurea grease.
John Deere TY6341 is a Polyurea based grease. Would that do the trick?
It should! I posted about the TY6341 a couple months ago. I had found a place that has it and ordered 2 cases. Been using it since. So far, so good...
But if you want the Lucas it is back in production now and in stock at Walmart so I assume back everywhere now or very soon.
That's great news for those that were missing it!
I work at a JD dealer, so I use the TY6341 in my home grease gun since I get it for cost + 10.
