Originally Posted By: Clevy
Originally Posted By: dparm
Not worth your time. It won't serve any useful purpose. Millions of cars go many days without being started. Unless you are going to drive it for 20-30 minutes and get the oil up to temp, you're just going to be polluting a lot and pumping thick oil around (accelerating wear).
Make yourself an Irish coffee and enjoy being indoors.
PS, currently -5 F with a windchill of -25 F here in the Chicago suburbs. I have no plans to go start my car until later in the week when I need groceries.
Not quite.
If my car isn't plugged in and its -30 out I've gotta start it and let it run for an hour every 6 hours or it won't start,period.
OP
If you need one of those vehicles to actually start I would run them once or twice daily for an hour. Yesterday my car wouldn't start after sitting for 8 hours.
Once ambient temps increase you'll be fine.
I suggest those who don't actually live somewhere cold to give some actual thought to their answers. If an emergency arises and he runs out there to start that car and it just "clicks" then the whole extra wear and fuel dilution argument doesn't mean much does it.
I wouldn't start both though. Just one,then it can jump start the other if required.
If some life or death emergency arises,God forbid,with the few dollars in few truly matter.
Just saying,coming from a guy whose been living with daily -30 temps and my car wouldn't start when I needed it to.
Do you have a problem with the battery or starter? My Cherokee has a pretty significant battery drain and in the extreme cold I do try to drive it every few days to work and back. I don't want the newer battery to freeze.
But other than that, I have had vehicles sit for a few days in these extreme cold temps and they start up. I wouldn't say start right up as the oil is molasses and the battery is low.
Will be interesting to see if the Focus starts tomorrow. The battery is only charging to 12V.
This is my Cherokee starting Over sitting overnight in -8 temps. Old battery cables and the parasitic draw did a number on the CCA, but it still started.
