No comment on Vollsynthese/fully synthetic is required.
"Technosynthese" is a moniker some oilmakers use for hydrocracked oil, which is also commonly called "Öl auf Hydrocrackbasis." Technosynthese sounds good, because it implies that this is a hi-tec oil.
Thanks guys, I had not seen the Technosynthese before and wasn't sure what it was. It was used in reference to Motul Dexron III.
Should still be pretty good stuff, even hydrocracked.
