Yeah, It’s a popular myth that keeps popping back up every release. I’ve had 3 including an M2 Comp.A friend had an M2 and I swear he said he had to do that. Then again he is a dealer only type guy and would believe anything they would tell him.![]()
The break-in service is free of charge. They also change out the diff fluid, or used to. The BMW break-in interval on M-cars is just as much about forcing the new owner to become familiar with this high performance vehicle before they take it to the track/spirited driving.It still limits power/RPM as well right? I always thought the 1200 mile oci was more to get you in the shop to remove the limits.
That started with E39 M5. Gradually dissipating yellow markers on rpm gauge. By the time that story comes from uncle’s daughter’s boyfriend dad’s friend, back to uncle, it is restricting rpms.Yeah, It’s a popular myth that keeps popping back up every release. I’ve had 3 including an M2 Comp.
What about Honda? lolThis is the correct answer in both regards, reference former lead manufacturing engineer and I managed parts washers for engine components. Unless you plan to sell the car at 40k miles.
really? no sense of humor ,as usualRegional has different meanings.
If you take a map, you might see there are other parts of the world. Not expensive, and you can find many online too.
you have just described they way i drive my bmw and its not new oneInstead, the best thing you can for a new engine is:
1) Warm it up to full operating temperature
2) Do several full throttle runs that stop well short of redline
3) Idle the engine to let it cool a bit
End quote.
It is internet, forum, not a crystal ball.really? no sense of humor ,as usual
it is an simple forum, not a show for "celebrities"It is internet, forum, not a crystal ball.
Again, many engines have a long life and good performance without an early change.FIXED
Does it help to do an early drain? No.
Does it hurt? No.
Does it hurt not too? No.
It’s pretty simple.
Cost is always a factor but, in this scenario, it is equated to a euphoric response after you do said early change. It makes you feel good, so you are ok with the cost and that is all that matters to you, personally.
Man I must just be lucky with all my vehicles without early first changes that went over 40k.This is the correct answer in both regards, reference former lead manufacturing engineer and I managed parts washers for engine components. Unless you plan to sell the car at 40k miles.
Unless and I've said this before you have quantifiable data that states it does over even just a few thousand engines you have nothing. Doesn't means it wrong but certainly doesn't prove any right in it. There is nothing measurable about it.Again, many engines have a long life and good performance without an early change.
But, you can’t define that an early change does not help as you have stated. So you make a false assumption.
In fact, it should be easy to surmise that it likely helps in some way. Small ways that are insignificant, or significant ways that could be measurable in some circumstances
Not that it absolutely does not help. Are you able to do that?
I able to say with great certainty that it doesn't help for the general public, maybe it makes a few oil nerds like us feel better (there is those immeasurable feelings again).
It's all an opinion not verifiable fact.'Immeasurable feelings' to whom? To customers? Probably. To manufacturers?
Definitely not. They know the difference, they know about manufacturing and
break-in contaminants. The crucial problem: Manufacturers have no interest to
share or, say, disclose their knowledge. Closed to the public and will be forever.
Talking with a couple of engineers in the industry let me to do early oil changes.
Before talking to them I didn't carry out early changes. Just like the vast majority.
