Any Volvo used oil analyses?
Alberta
Good day,
Longtime lurker and just joined as I don’t see as much info as for our other engines (Cummins 6.7 and VW 2.0 TFSI) I don’t see many Volvo used oil analyses on here, so I’m just curious if many people have some filed away for the 2.0 gas engines. We’re picking up a 2026 XC40 soon and will do an early oil change or 2 and have the odd used oil analysis done and would like something to compare to. If not, that’s fine and I’ll try to update this thread with my own. I’ll stick with dealer provided oil at first and then try Liqui Moly or Amsoil to compare after the break-in metals dissipate. Or maybe something else as I come across it.
Thanks!
Try to find the newest Blackstone sample on this engine to get a decent idea of average use. I thought this engine has been around since 2016? Not certain but perhaps try one of the Volvo forums too. Perhaps, a lot of Volvo owners have them changed at oil lube stations? I change my own but mine is 18 years old & not the engine you're after.
Just had the first official oil change on our 2025.5 XC-90. Same engine as yours. Our XC-90 is the T-8 plug in hybrid.
Done at the dealer. Didn’t get the chance to pull a sample.
I did change the oil early, and surreptitiously, because it’s under warranty, and I’m glad I did.
I did it with approximately 1000 miles on the engine and oil was silvery, though the particles were too small to see individually, they did reflect light. The Volvo filter had only a few flecks.
I cant help with the oil analysis but the XC40 is one of the better Volvo's. After 17 years of working for them, I generally no longer recommend the other models to anybody once the chinese parts and cost cutting started to take a foot hold. The amount of 2022 XC60 buy backs I saw was ridiculous. Plus the amount of AC evaporators I saw fail on the XC90 and XC60 is tough when you are out of warranty and its $4k-$5k for replacement.
Do you mind sharing which aspects of the XC40 inspire this statement?
I mean, it's rather obvious when reviewing the countless publications touting great reviews, but from a Volvo master tech, what do you find most appealing?
Here's just one of the reviews from C&D I'm referencing:
https://www.caranddriver.com/volvo/xc40
It is a simple car. Has a good engine, rarely any HVAC issues like the larger platforms, and it is fun to drive. No suspension issues have arisen. Granted they can have their individual gremlins but overall its a good car.
The biggest failure among all Volvo's, including the xc40, is the touch screen and how slow it is to boot. The lack of HVAC buttons compared to my audi means you sit in a hot or cold car for a few minutes waiting on the screen to boot up so you can adjust the climate control.
NOTE: I left volvo in 2022 so I cant comment on the 2026 model with personal experience but my friends still at the dealership dont have much to say about the newer XC40s.
This is very helpful, thank you :)
Thank you, I will do a few samples early in the engine life to get a baseline going and post them on here as I receive them. As the car isn’t expected to arrive until end of March, it will be a few months until I post the first one.
I recommend doing an oil change at 2k miles and another at 5k. Then do it every 5k after. This is what I do on my Audi and will never fall for the 10k oil change.
HOWEVER.... I never saw a Volvo engine fail due to an oil or carbon issue. The 10k OCI seems to be ok on the Volvo VEP engine using the castrol edge professional 0w20. Most engine failures were timing belt tensioner failure or spark plugs coming apart and destroying the cylinder or valves burning.
Yes that’s roughly what I’ll do. I doubt I’ll ever go the full OCI on it.
Ok I’m currently at 1200kms and carrying out an early oil change tomorrow. I wasn’t planning on getting a used oil analysis just yet but is there much interest for me to have one done at this point? Otherwise I’ll get one for sure after 3-3500kms when I change the oil again. Let me know if you want a used oil analysis at this point.
Cheers,
Why would you sit in hot or cold air? Are you not setting a comfortable temp and letting it handle it the way it's designed? 68F and auto fan speed 3 and I've never had a complaint about air temp in mine.
Exactly - you don’t need to tell the climate control how to cool the car, it will move enough air and set the temperature if you allow it to choose. Don’t treat it like my parent’s 1976 Impala, where you set the slider and fan speed and push the AC button manually. The car is capable of doing all that from the moment you turn it on.
Our Volvo is connected to the app - if I am actually worried about getting into a hot/cold car, I just tell the climate control what temperature I want, via the app on my phone, and it will be ready when I get in.
So easy.
So easy.
The number of customers I have that don't understand this is staggering. "I hate the fan speed controls in this car! It's always too high!" Well yeah, you have it set to as cold as it can get and the car is doing whatever it can to freeze the interior. 😄
Depending on where you live, you have the heat on to drive in to work in the morning and when you come out in the afternoon with the sun beating down, you need the AC which takes forever to adjust during boot up. Just setting the car at 68f was never an option for me as the car needed to cool or heat faster for my liking. Here in Germany, its like 35f in the morning and then 65f in the afternoon. Wilmington, NC was far easier because I did just leave my Volvo S60 at 68f.
But this is why I will never own Volvo again or a new Audi, my 2024 S5 is the last car I hope to buy because it has physical HVAC buttons.
FYI - Customers that mash the screen while boot up only make the wait time longer. I hated consumers when I worked as a tech. The complaints about fan speed/noise too when temp set to low/high and fan speed set to auto. I would always tell them to "Read your manual"
That's exactly what he system is designed to adjust for. That's why the fan speeds are higher when the cabin temp is warmer.
I am going to assume you never owned a SPA volvo. If you have it set to 68f, it will not rush to cool the car down like it would if you set it to 60f. It will literally make the air 68f and then start blowing it slowly if set to auto. Of course you can manually bump the fan speed up but then again.... boot up time.
First early oil analysis done.
