Originally Posted By: SonofJoe
Ducked,
In answer to your many questions...
Ahem. I asked some questions earlier because I didn't/don't intuitively understand oil carry-over by fuel.
This bit was mostly statements, though you may well be correct to disagree with them.
If you condense the steam/fuel strip-out and separate the two immiscible phases (which would be normal), then what do you do with all that foul water?
Yeh, I said that was a problem (twice, IIRC), and gave it as one reason for running a total loss system.
If you don't condense the steam/fuel strip-out and direct the entire flow to the intake system, then you do one of two things. First you risk changing the dynamics of the whole intake gas flow. Water is 'funny stuff' compared to virtually all hydrocarbons in that for a given weight, it expands to a far greater volume. Given that gas flow rates are so critical to tumble and swirl, I can only see change as being negative.
You'd clealy have to limit/control the water delivery, (and the available quantity will be limited anyway) but "I can only see change as negative" seems to ignore the fact that water injection has known real benefits. Our imaginary system won't be optimised for those benefits, but they do demonstrate that water is not inevitably negative in its effects.
The other scenario is that the vapourised steam/fuel strip-out hits the cold air in the intake system and instantly condenses to create fast moving stream of water & fuel droplets. Might these erode the top of the inlet valves and valve seats? I don't know but I suspect they could.
Well, again, water injection is a partial precedent here, and as I said above, the experience with direct injection engines is that they get coked up with blowby condensate, so a bit of erosion might not be a bad thing. I doubt the water will cure the coking problem completely, but it might help.
As I said, I think the real killer of any such system is not the cost, but that it would complicate the ownership experience (because they'd have to put water in it) and that is never going to be commercially acceptable. Commercial experience with water injection systems again provide a comparable example.
Regarding the vacuum thing. Is your crankcase really operating at that much vacuum? I sort of doubt it.
What much vacuum? I didn't give a level, and I've never measured it. Suppose I should, but my understanding was that in general old-fashioned throttle controlled petrol cars tended to maintain the crankcase at negative pressures. If you mean it isn't exposed to FULL engine vacuum at idle, then you are probably right, but I didn't say it was.
I tried to find some examples of typical crankcase pressures a long while ago for something else. Here they are, though I don't know if the links are still live.
Its quite hard to get figures for “normal” petrol-engined cars, especially bangers.
This thread goes into “How to test the BMW E39 pressure-controlled crankcase ventilation system (CCV)?” in rather obsessive detail
http://www.bimmerfest.com/forums/showthread.php?p=5989795
That’s of course a rather different car and system to mine, but 4WIW
“A properly functioning pressure control valve is designed to maintain a slight vacuum (approximately 10 - 15 mbar ) in the crankcase which assures reliable crankcase venting during all engine operating conditions.”
This at least seems to establish the general principle. (which is the opposite of that stated in the Detroit Diesel link below)
A few pages down, actual readings are reported for an M62tu engine
“Eng Temp-----RPM---------Vacuum in inches [of water]
Cold-----------1300--------4.64" (at startup, Sec air pump running)
54°C------------600--------3.61" (Sec air pump just stopped)
70°C------------550--------3.58"
80°C------------500--------3.37"
93°C------------500--------3.32"
102°C-----------500--------3.29"
108°C-----------500--------3.28"
If the engine was held (1500-4000 RPM) the vacuum was 2.92"
The RPM didn't matter.”
I'm not sure my system has any control valve, the crankcase seems to simply connect to the air cleaner via a baffle. I might be wrong about that though.
This guy
http://www.eng-tips.com/viewthread.cfm?qid=304717
reports on a 1971 Triumph 2.5 litre saloon (nice shape, IIRC) which is arguably a more comparable level of (lack of) technology.
He was getting - 6psi (i.e below atmospheric) at idle, and -1 to 2 psi at 80 mph. Above that no reading, but he apparently couldn’t read positive pressures on his gauge, so it’s a fair bet it went + flat out.
He was testing a second DIY breather that he’d added, so perhaps a stock system would go positive earlier. OTOH, he did suggest that Triumph used a one-size fits all system which was under-capacity for the 2.5L.
In high performance (especially turbo’d) engines, blowby, piston pumping and heating all increase and may cause crankcase pressurization, to the point that some racers apparently fit vacuum pumps to their sumps (?). I suppose the higher compression of diesels might also result in more blowby.
http://speedtalk.com/forum/viewtopic.php...tart=15#p260224
At least some diesels (not throttle controlled, of course) seem to be different.
http://constructioncranes.tpub.com/TM-5-3810-293-14-P-3/TM-5-3810-293-14-P-30119.htm
I found some specs for some Detroit Diesel engines which seem to max out (as in, reach the limit of acceptability) at 1” of water at 28000 rpm.
They suggest that “A slight pressure in the crankcase is desirable to prevent the entrance of dust.”
This implies (though it doesn’t actually say) that slightly positive pressures are “normal”.
However, according to Racor, who make crankcase ventilation systems (surprisingly, emission control of diesel crankcase vapours apparently wasn’t required in the US until 2007) at least some diesels may be at negative crankcase pressure during normal operation.
http://www.parker.com/literature/Racor/7678%20(CCV%20Technical%20Brochure).pdf
“The third integrated feature of the CCV is the pressure regulation valve. It balances the pressure in the crankcase, protecting it from the high vacuum created by a dirty air filter and todays high mass flow turbocharged compressors. Our pressure regulation valves monitor crankcase pressure ensuring that it maintains a range of -4 to +4 inches of water ”
There are various graphs showing crankcase pressure against turbo restriction, inlet pressure, etc. They are mostly negative, and the implication seems to be that, without the Racor system, they would be more so.
