Some years ago, a recognized industry expert, Terry Dyson, posted regularly on BITOG.
There was a long running thread involving this expert and a member who had some sort of very high-po Audi that had terrible fuel dilution problems.
A number of used oil analysis were done, which showed that the fuel dilution was having a significant impact on engine life.
The ultimate soloution was for the owner to use an ester basestock oil in his engine, from RLI.
I wonder whether fuel dilution problems might be reduced with your engine if you tried an ester based oil?
G-oil is such a beast, Dexos 1 or not, and it is certainly fairly inexpensive, if it works, while RLI oils are more costly.
I'm just throwing this out there in case you would want to consider leaving the Dexos 1 spec behind and searching for an oil that might really work in your situation.
