The leaf spring must have broken during use.
If the leaf spring was missing or broken out of the box, you would have had start up clatter from dry starts for a very long time, especially in the Winter.
Also, if the element was rattling around in the can, spinning it on you would have noticed. An oil filter has to be turned many, many times until it snugs up to the engine block. You would have felt the counter movement in your hands for sure, or even heard it moving in a quiet home garage.
Even when handling a dry filter that is rattling, even to lube the nitrile base seal, it would have caught your attention.
My guess is your Blackstone results will be fine. This is a recent failure.
An oil filter leaf spring is in constant flux as engine RPM changes from waiting at a light to accelerating.
That was a long time and a lot of compression/expansion cycles for a little sheet of spring steel.
This again cements the view that changing an oil filter every OCI or every 3-5k miles may be prudent. They don't only filter, they are mechanical devices that actually move when in use.
They have seals, pleats, springs and vary opening amount constanly based on oil pressure changes based on engine RPM. Best to not milk them as they are cheap and easy to change.
