Originally Posted By: Keto
Originally Posted By: KCJeep
That's nice, you'll fit right in with all the other self proclaimed internet engineers and experts here.
I am a self-proclaimed Engineer! My Alma mater proclaims it, the State DCA licensing board proclaims it... its proclaimed a lot!
What are your self-proclaimed qualifications?
In an oil filter, not so much.
In your imaginary world, perhaps. Metal end-caps typically provide a static seal with minimal assembly pressure, vs cardboard "fiber" which would require more substantial pressure to maintain a proper seal, like gasket material would normally be subjected to. In the 6018's I've disassembled, there appeared to be seepage between the intake and exhaust channels, particularly on the edge where the bypass assembly fits into the core. The 7317's had similar characteristics.
K
If you're a self proclaimed engineer, then you would know that saying you work with hydraulics and therefore know about engine filtration would be like a person saying they are a gun expert because they fish.
Hydraulic systems and engine oil: Two different things.. I would hope you'd never use a Fram engine filter in a hydraulic system. One uses much higher PSI.
Still not sure how you get the word cardboard out of fiber? Its a paper cellulose/ synthetic media blend. Much better than materials than its same tiered competition uses IMO.
By all means, use what you want.. Just don't make false claims especially if you prove to know nothing about them.
K
