Originally Posted By: sayjac
For the OP, is there some reason why this application uses the extra adbv? Does it have something to do with the orientation of the filter? Does it have something to do with the engine design? Have you used other filters without the extra adbv and noticed a difference at start up as far as nvh, start up rattle?
The Motorcraft FL-2005 has this - which it calls the "anti-siphon" valve - for the Zetec motor. Not sure why they spec-ed it. I don't believe the 2005 is available anymore.
I've used both the 8316 (with this anti-siphon valve) and the 3600 (without the anti-siphon valve) on two different cars, but neither was mine. I cannot comment on noise at start-up, but never heard any complaints from the drivers, so I assume they were OK.
Honestly, I got these filters at an oil change special (have a bunch of the MG8316, same design). The only reason I went with the 8316 instead of the 3600 is (i) I feel a little better with the filter holding a little more oil, and (ii) since the 8316 was more money, I felt I was getting a "better" deal
