What was your point in saying "(don’t know if they are rated in miles) …" in post 32?Your assumption - Nothing unclear in what I wrote - the Super Tech picture was already there - and have used that exact Super Tech filter …
Forget about it …
Forget about it …
A Champ Labs product made FOR Fram. Why is anyone's guess..
That looks like the common Champ built filter like K&N and Supertech.
Saw this video where someone cut open an PH7317 and it had metal end caps and ecore. Apparently they got it from Amazon, so I don’t think it should be counterfeit? Also no silicone ADBV, but I’ll take this instead since Hondas have filter under the engine.
I bought one from Amazon to check, will arrive tomorrow.
More pleats, probably due to the eCore center tube to keep pleat spacing tighter, but less total media area due to the pleats not being as deep.
I purchased one but did not get a new build date where this change happened. I got an old style. It was cheap though, only $3.5Have you purchased the PH7317 and confirmed it yourself and posted the C&P on the forum?
Are Fram Drive and Extra Guard the same filter? Wonder why drive doesn’t have the 10k rating if that’s the case.^^^ I know repetitious but I'm going with the former, authentic First Brands Champ Labs made "Fram". Especially since they already exist under AAP "Drive" moniker. Just add sticker and Sure Grip dip/spray, same filter.
The latter too elaborate a ruse, to what point and/or goal, can't see it. That said, conspiracy theories are a more attractive answer.
The Fram Drive was originally a different filter, essentially just an orange painted Champ Labs jobber filter, while the Extra Guard had more efficient media, a silicone ADBV, and grippy paint on the domed end.Are Fram Drive and Extra Guard the same filter? Wonder why drive doesn’t have the 10k rating if that’s the case.
If that happens, the Subaru -AA15A filter should get that update too? Though, if the dealer is now selling E-Cores, they might have been beta testing them.Fram has updated the graphics online for both the PH and TG.
Be interesting to see if the Honda A02 follows suit.
The labeled "Fram" Drive is a 'made for' Advance Auto Parts (AAP) by First Brands-Champ Labs. It's likely similar to the Champ Labs made Super Tech ST series but 'afaik', all use the metal caps and separate dome bypass. They also have an orange color can use a sticker label. FB apparently chose to call the Drive with nitrile adbv good for 7500 mile fci, perhaps in coordination with AAP. The ST series is labeled good for 10k, MP with silicone 20K. Perhaps in coordination with WM. Beyond difference in adbv material, I don't think anyone has proven any other difference one way or the other between ST and MP.Are Fram Drive and Extra Guard the same filter? Wonder why drive doesn’t have the 10k rating if that’s the case.
Either Fram has made a change, or Amazon has gotten a bunch of counterfeit filters
