No such thing as "better oil flow" when a PD oil pump is forcing oil through the filter. More base plate holes and an eCore center tube would produce a hair less delta-p across the filter assembly. The only time a filter with less delta-p will "flow more oil" is when the PD is in pressure relief, which hardly ever happens unless someone revs an engine really high with very cold thick oil.
