Fram Endurance Flashlight Test in canister
No worries on Boss torn media. If the louvers are open run it. The Pure One seems hit or miss on wavy pleats which could tear. This is the only recent defect I could find.
Correct on the Boss, but I'm not going to use those due to the efficiency issue (which is more of an inherent problem).
On that Pure One thread you linked, the issue was not media tearing, and I'm of the opinion (expressed by some others) that that filter was likely sealed properly and filtered fine.
Either way on that, that was last May and seems to me that it's been a while since we've seen a torn Purolator.
In this thread, @ZeeOSix explained his theory as to why the fiber end caps of the EG and TG should be less susceptible to leakage at the leaf spring fitting, but I noted that we have seen recent examples of both EG and TG's leaking. I even went on to make a Bayesian argument that those filters might still be best to avoid despite his theory.
He countered that "A few bad examples doesn't mean they are all like that. Anyone reading this forum for a while knows every filter brand has some issues now and then that or outliers, not the norm." No one argued against that, and he could be right, so I dropped it.
But if he is right, I would think that fact that recent examples of bad Purolators have been few and far between (and not involving the notorious tearing issue), might mean that maybe we here at BITOG could be guilty of judging these filters based on conventional wisdom about tears that are out of date.
Wavy and wide pleats lead to tears. The one I posted was a perfect candidate and with Purolators history it’s a gamble. I also believe the metal caps not being glued correctly is a defect.
I also pointed out that a light leak test on the leaf spring to a fiber end cap needs to be done with the leaf spring in the same exact position/orientation it was in before the filter was cut open. The pressure of the leaf spring isn't totally even around the circumference of the center tube due to the design of the ears on the leaf spring, so the fiber end cap takes a "set" that matches how the leaf spring was seating on the fiber end cap. The examples that showed some slight light leakage clearly showed that there was a 100% impression around the center tube in the end cap from the leaf spring pressure, so it should be sealing if the leaf spring is put into its original assembled position.
Wide pleats, yes. But wavey? I also don't like it when there are waves in the pleats, but that was another long discussion that @ZeeOSix was involved in, and, if I remember correctly, he did not agree that there was necessarily an inherent problem with waves.
You're probably right that technically it was a defect, but my guess is that it is more of a cosmetic defect as I think it's the glue-- not the metal-- that is responsible for the sealing. So, if the glue is there and sealing the ends of the media, I'm thinking the end cap on those filters is probably superfluous.
Of course, I have no expertise in any of this and could be wrong.
But your point about the history of a product affecting the conclusion drawn from a given bad sample was exactly the argument I made to ZeeOSix, he shot that argument down, and no one else defended it.
So, if "there are always going to be a few bad examples" applies to the Fram EG and TG, I'm thinking that it applies even more strongly to the Purolators given there have been few bad examples of late.
I scanned this forum a few months ago for torn media on C&P threads over the year, and only found five cases as summarized below. Torn media still happens, but seems relatively rare these days.
Feb 16, 2024
Mobi1 1 212A (made by Mann+Hummel)
LINK
Mar 7, 2024
PureOne PL14477 (old yellow version)
LINK
Mar 8, 2024
LINK
Mar 31, 2024
NAPA PROSELECT 21348
LINK
May 3, 2024
Napa Gold 7712
LINK
Yes, wide pleats combined with non-wire backed and brittle media can cause tears from the force of the oil flow. Wavy pleats without wide pleat spacing does not cause the media to tear.
Yes, you did make that point (and I agree with it), but that wasn't the focus on my bringing it up. The point I was making to @Glenda W. involved the fact that you disagreed with my "Bayesian rejection theory" based on the idea that all companies will make a few bad examples.
I was saying to her that it would seem that if your argument can be used to support Fram (given the higher rate of faulty examples recently), then it should really apply to Purolator which I believe has had very few failed examples of late.
Yes, wide pleats combined with non-wire backed and brittle media causes tears from the force of the oil flow. Wavy pleats without wide pleat spacing does not cause the media to tear.
Great-- I remembered it correctly, then!
Feb 16, 2024
LINK
Mar 7, 2024
LINK
Mar 8, 2024
LINK
Mar 31, 2024
LINK
May 3, 2024
Napa Gold 7712
LINK
It seems to me that torn media and closed louvers are the big knocks against Purolator.
Your data here indicates that perhaps the "Purolator media tears" argument is now something from the past and that now maybe we should move on.
Would you agree with that?
If so, combining that with the fact that if buying in person one can avoid getting closed louvers, do you think that maybe we should stop saying that Purolator filters should be avoided?
I understand why Purolators got blacklisted originally, and it made sense. But now I'm starting to wonder if all the negativity on this brand is currently just inertia from past events that are no longer being supported by current evidence.
You said:
"In this thread, @ZeeOSix explained his theory as to why the fiber end caps of the EG and TG should be less susceptible to leakage at the leaf spring fitting, but I noted that we have seen recent examples of both EG and TG's leaking. I even went on to make a Bayesian argument that those filters might still be best to avoid despite his theory."
In order for a test to be valid, the test needs to be ran in manner that represents reality. What I was pointing out about the EG and TG fiber end cap Frams (and any and all other fiber end cap filters for that matter) is that you can't really conclude they have the same leaf spring leakage problem as the metal end cap filters with warped and ruffled leaf springs. On the fiber end cap filters, the leaf spring takes a unique "set" in the fiber end cap because it's under compressive force while assembled and that puts a corresponding and matching impression in the fiber end cap. So if the leaf spring is not tested with it in the same exact position as it was when assembled then it may have a small gap and show some light leakage. If the filter dome was cut open without cutting open the filter like done in post 1 of this thread, then that would be testing it in the assembled configuration. Also, as pointed out too, if the center tube is bent inward (like in the one BR test video), or is too long and sticking up enough to prevent the leaf spring from fully seating on the fiber end cap, then that could also cause a leak path. But overall, I'd say filters with fiber end caps are going to have a better seal than these ruffled up leaf springs on metal end caps seen lately.
So jumping to the conclusion that the EG and TG fiber end cap filters also suffer from leaky leaf springs is more than just a Bayesian argument. But that argument could be used that all brands of oil filters will suffer from some kind of defect ... that's been seen here for decades. When you start seeing repeated defects on the same brand of filters over an over, then it's pretty apparent there's a systemic issue going on .... like when media was tearing constantly on the yellow Purolators and now the air gapped and leaky leaf springs on metal end caps with only the metal-to-metal contact "seal".
Closed louver can happen on every brand that uses them. Same with torn media ... I gave some examples above with links to the main threads of those examples. I've seen examples of the same filter model may have well formed louvers, and the another of the same model have mere slits and pretty choked down louvers. It's a manufacturing inconstancy issue. Of course anyone that understand this should be carefully inspecting any filter they buy and plan on using with a good LED flashlight and decide if the louver look good to them or not.
Maybe ... but seems there are way less people cutting and posting used Purolator filters. So who knows without a decent number of C&Ps.
Yes, as said above ... always inspect louvers and decide if it makes you feel good about using the filter. I don't anyone is out right saying avoid Purolator filters. People post C&Ps and talk about certain Purolator efficiency numbers ... so with discussions like that people who read the imputs should decide what filters they want to use.
Not as much inertial as before, but there are other things pointed out about every filter brand where people can then digest that info and decide for themselves which filter(s) to use. We are seeing that going on right now with the rufflled up and leaky leaf spring stuff.
After 5 calls to Purolator I’m at a loss. I was told every filter has it own data sheet which is updated if there’s a production change. The service reps generate the spec sheets on demand so updates are seamless. I was told each filter could have a better or worse efficiency then what is marketed. The Boss marketing materials are based on PBL 30001 being 99%@25 microns so I requested that spec sheet and two more that @Fair enough might be interested in. As you can see below nothing is matching up to the marketing claims. I give up…
Seems M+H Tech Dept is confident that those Spec Sheets are valid. Did you ask why Purolator's website shows a much better efficiency than the Spec Sheet for the PBL30001? The whole PBL30001 non correlation between the website efficiency claim and the Spec Sheet has been pointed out quite a few times, but the mystery can't be uncovered.
No, only because I received the spec sheet after my conversation. According to the rep the PBL30001 spec sheet should have matched the marketing. I was confident it would. Now I don’t know what to believe.
At this point, I wonder if anyone at Purolator/M+H can answer that question without some deep digging on why they don't match for same filter (PBL30001 in this case). There's a big difference between 99% @ 25u (website footnote claim) and 99% >46u and 50% @ 22u (official Spec Sheet claim).
Oh…I asked where the spec sheets are generated from. He didn’t know😂
In order for a test to be valid, the test needs to be ran in manner that represents reality. What I was pointing out about the EG and TG fiber end cap Frams (and any and all other fiber end cap filters for that matter) is that you can't really conclude they have the same leaf spring leakage problem as the metal end cap filters with warped and ruffled leaf springs. On the fiber end cap filters, the leaf spring takes a unique "set" in the fiber end cap because it's under compressive force while assembled and that puts a corresponding and matching impression in the fiber end cap. So if the leaf spring is not tested with it in the same exact position as it was when assembled then it may have a small gap and show some light leakage. If the filter dome was but open without cutting open the filter like done in post 1 of this thread, then that would be testing it in the assembled configuration. Also, as pointed out too, if the center tube is bent inward (like in the one BR test video), or is too long and sticking up enough to prevent the leaf spring from fully seating on the fiber end cap, then that could also cause a leak path. But overall, I'd say filter with fiber end caps are going to have a better seal than these ruffled up leaf spings on metal end caps seen lately.
Yes, I understood that at the time and don't disagree with any of it (then or now). Note that I dropped the argument in those earlier posts as I understood and agreed with your point and didn't want to take it further.
My Bayesian argument = if a company has had problems in the past, the probability of a new bad example indicating a larger problem is higher.
You = Bayesian doesn't work here because there is a high likelihood that when people did the flashlight test, they didn't get the leaf spring lined up with the "set," which means that there may not have been a real failure.
Me (in my head) = Yeah, that could be true, so I'll let it go.
But that arguement could be used that all brands of oil fllters will suffer from some kind of defect ... that's been seen here for decades. When you start seeing repeated defects on the same brand of filters over an over, then it's pretty apparent there's a stitemic issue going on
Again, I agree and this is the only thing I was referencing from you as the context for my response to Glenda. Probably didn't even need to reference you as it's a fairly obvious point.
True, but my only point was that, if you're buying in person, this is at least a defect one can determine before purchase (as opposed to media tears or leakages which cannot be determined in advance).
So, not trying to pin the louver problem on Purolator exclusively, just saying that it is one of the arguments against using Purolator but it seems like a problem that can be mitigated.
That could be a factor. I thought of that and almost included that in my post but decided not too since I didn't want to take the time to check to see how many Purolators had been posted of late.
I disagree with that-- there are many people who have many, many times posted "stay away from M+H filters" as a complete and absolute blanket statement.
Yeah, I'm following the efficiency discussion as well, and it's an issue. But that problem seems to be centered around the Boss. I've not seen anyone question the red or blue cans-- they seem to be fine. So, I'm not really talking about that in my posts here.
I could be wrong, but I'm starting to believe that people today who say "stay away from Purolator because it's made by M+H which should be avoided entirely" are making those statements ~95% based on (real) past problems that seem to have little evidence of being a problem today-- the definition of "inertia."
BTW, all these arguments (I believe) apply to Wix as well, assuming you don't buy them online and can inspect the louvers before purchase.
