I search for a gasket, and use that with Permatex High-Tack. RTV sealant is a last resort, when no gasket is available or can be made.
But why? RTV is a far superior seal on applications that were designed for it.I search for a gasket, and use that with Permatex High-Tack. RTV sealant is a last resort, when no gasket is available or can be made.
So for some reason I'm not having good success with a lower oil pan replacement on the Altima. There is no gasket for the 2.5 so I have to use RTV. The first time around I used black. It's leaking almost all the way around and I know I coated and cleaned everything good. Wondering if I didn't wait long enough before tightening it down. Does it have to harden up a little bit first? I'm not sure what the torque would be but I'm assuming not much?
Never seen it. I've seen Toyota transmission cases sealed with their special pink rtv and those have never leaked IME. But most of the newer tight fitting items are sealed with anaerobic sealers, not rtv.Far from it. Like I said in the previous post look at split cases that use it OE.
How hard an RTV gets, or how hard you let the RTV get before assembly is not what I am talking about. All RTV hardens. A "non hardening" sealant like Hylomar does not harden, and is not an RTV. RTV as a gasket or gasket dressing is sometimes known to fail because they are a hardening type compound. Once (for whatever reason) the silicone bond becomes un-adhered to the the surface being sealed, it allows oil or AF or whatever to seep underneath and leak. Non hardening like Hylomar stays tacky and does not become un-adhered. Hylomar is generally used as a gasket dressing, but is also rated as a flange seal and suitable for what you are talking about here, assuming the mating parts have not been damaged/distorted."Hard" RTV is not the problem, unless you're allowing it to get too hard before joining the surfaces. Although all my wrenching and most of my forum time is spent with diesel trucks and not Altimas, I have heard far more problems with oil pan gaskets than RTV. And if the factory did not spec a gasket for your oil pan then it's best not to use one. Surfaces have to be perfectly clean and free of any oil/grease residue and the torque has to be on point as well. From the OP's post it sounds like the exact torque values are not known so I would venture a guess that a combination of inaccurate torque values, perhaps improper torque sequence, and maybe the wrong RTV all added up to a leak. Just my .02. My oil pan still has factory grey RTV not leaking with 360k, YMMV.
Knowledge lever?Can always gauge the knowledge lever of a forum when a post like this comes up. No mention of a "non-hardening" option like Hylomar, that is not RTV. Strands of escaped RTV gasket maker great for clogging oil passages, though.
Right around drain level.Knowledge lever?
You don't say
Its FIPG and This was going to be my exact response. It’s the absolute best period. Permatex has something similar mentioned as well a few post back called the right stuff. I’d definitely go with FIPG myself.use genuine Toyota FPIG (formend in place gasket) - expensive but when was the last time you saw a leaky Totota?
Oh I see. I thought it was haste and not going back to read what you wrote. You know.Right around drain level.
aka circling the drain. you know, round and round in a downward trendOh I see. I thought it was haste and not going back to read what you wrote. You know.
Time might be short.aka circling the drain. you know, round and round in a downward trend
Might makes right.Time might be short.
This is certainly not an application for Hylomar, Far to many imperfections in the steel pan flange. All you have to do is look up the "Gap Fill" specifications for Hylomar M & Universal Blue. Don't get me wrong.....I have Hylomar M on my work bench at all times & use it a lot!How hard an RTV gets, or how hard you let the RTV get before assembly is not what I am talking about. All RTV hardens. A "non hardening" sealant like Hylomar does not harden, and is not an RTV. RTV as a gasket or gasket dressing is sometimes known to fail because they are a hardening type compound. Once (for whatever reason) the silicone bond becomes un-adhered to the the surface being sealed, it allows oil or AF or whatever to seep underneath and leak. Non hardening like Hylomar stays tacky and does not become un-adhered. Hylomar is generally used as a gasket dressing, but is also rated as a flange seal and suitable for what you are talking about here, assuming the mating parts have not been damaged/distorted.
I find a gasket much easier "when available." Bottom line imo is if the part in question doesn't leak after the repair, the job was done well. My 08 Liberty's transmission pan didn't use a gasket off the assembly line, but a replacement gasket was available for servicing the transmission. Using an RTV type product to reseal the transmission pan imo would have been a fools errand. @Trav and I had this discussion numerous times, and here's what I got from it. What people fail to realize is when a vehicle like my Liberty's transmission was assembled it never had ATF in it, everything was clean and pristine. Fluid getting onto the parts being assembled was not an issue. Then it ran down the line in a position where a robot applied the RTV and put the pan on it. Later the unit was filled. That wouldn't be so easy to do when servicing a transmission in a vehicle that was filled with AFT and driven. Which is why so many people have issues. Keeping certain surfaces 100% oil/fluid free and perfectly clean isn't always done right. So in my case using a gasket was the better way to go, even though it came from the factory w/o one.But why? RTV is a far superior seal on applications that were designed for it.
The parts store and the dealer told me there is no gasket so I didn't look hard enough. I should have because I just found this. Hopefully it won't be too tight it's already really close to the crossmember https://www.ebay.com/itm/Fel-Pro-Lower-Oil-Pan-Gasket-Set-for-2002-2013-Nissan-Altima-FelPro-Engine-cl/123867462678?hash=item1cd7137c16:g:2cMAAOSwyuVd0ReM&fits=Year:2006|Model:Altima|Submodel:S|Engine+-+Liter_Display:2.5L|Make:Nissan|Trim:S+Sedan+4-Door|Engine:2.5L+2488CC+152Cu.+In.+l4+GAS+DOHC+Naturally+Aspirated
I'm well aware of Hylomar and it is a fantastic gasket dressing. If an oil pan is moving independent of the rest of the engine then you have a completely separate issue from sealant/gasket/RTV/whatever, and using a flexible compound, if it even worked, would only be a temporary fix at best. If someone had mentioned Hylomar as a fix before exhausting all other options then I might question the relative status of the forum's "knowledge lever".Hylomar does not harden
Was waiting for the OP or someone to point out that there certainly is supposed to be a gasket in this application. Hylomar is the only gasket dressing ever to use. RTV has virtually no use where it is superior as a gasket dress.This is certainly not an application for Hylomar, Far to many imperfections in the steel pan flange. All you have to do is look up the "Gap Fill" specifications for Hylomar M & Universal Blue. Don't get me wrong.....I have Hylomar M on my work bench at all times & use it a lot!
With good prep.....Ultra Grey works very well for this particular application.
