What is the capacity of the PTU ??
Tell 'em "transfer case"?I had my wife’s Edge PTU fluid change done at a large dealer at about 30k. They were confused about what I wanted and it took the third person I talked to before they understood. Clearly not something frequently done.![]()
I’m reading right around a quartWhat is the capacity of the PTU ??
The rear diff holds a little over a quart. Your PTU only holds about 18 ounces or so. That’s part of the reason the fluid gets trashed so quickly; there’s so little of it. Even mine, which holds more, still only holds 24 ounces. Still way too little IMO.I’m reading right around a quart
The PTU holds a bit over a pint when new but you won’t get that out after use through the combo fill/drain hole. It gums up.The rear diff holds a little over a quart. Your PTU only holds about 18 ounces or so. That’s part of the reason the fluid gets trashed so quickly; there’s so little of it. Even mine, which holds more, still only holds 24 ounces. Still way too little IMO.
Is there any way to overfill it to add more? Just thinking here. If the design didn’t change and they just raised the fuller plug could that be done somehow?The rear diff holds a little over a quart. Your PTU only holds about 18 ounces or so. That’s part of the reason the fluid gets trashed so quickly; there’s so little of it. Even mine, which holds more, still only holds 24 ounces. Still way too little IMO.
Im going to just haven’t had time and forgotThe PTU holds a bit over a pint when new but you won’t get that out after use through the combo fill/drain hole. It gums up.
This pix was posted on the Flex site I mentioned, drained from PTU at around 23k miles. Trick is to do it often as a PM measure. The tool and fluid the guy used shown.
You really should check out the Flex site I mentioned when getting into the nittygritty of Flex ownership maintenance.
View attachment 186415View attachment 186416
Watch this video. All your questions are probably answered and it shows how to do the procedure.Im going to just haven’t had time and forgot. I read someone said you can refill from the top with a long piece of hose as well. Every heard that?
No unfortunately. Too much fluid can be just as bad as not enough. Will likely foam and cause overheating. Will likely shoot out of the vent port also.Is there any way to overfill it to add more? Just thinking here. If the design didn’t change and they just raised the fuller plug could that be done somehow?
Repost. Deleted lolThe PTU holds a bit over a pint when new but you won’t get that out after use through the combo fill/drain hole. It gums up.
