Originally Posted By: Gary Allan
Quote:
What's in red text above is a point we don't see the same. For one thing, WIX never qualified their "2 PSID" comment. I'm assuming they would mean on the "typical" Grandpa car driven like a Grandpa. That's all fine and dandy. You have locked into your mind that this is the way it always is ... and don't consider all the conditions that could give a potentially higher filter PSID.
So ..you're now ADMITTING THAT GARY'S RIGHT?????
Well, just when does Gary's right evaporate and Soupy's right take hold
Just when?
You're obviously in a non comprehensive state. You think that comment of mine above is admitting that you are always right? ... not even close - you are still wrong on some pretty easy to see issues. Ya, I've agreed many, many times that in most cases the filter PSID is probably pretty small, and the filter hardly ever goes into bypass mode on most Grandpa vehicles ... if I had a dollar for every time I said it, I could buy you another keg of brew.
I've qualified this over and over, but you're in some kind of zombie state and not picking this fact up. But someone else that's a "Gary buddy" on the board says the same thing and your all over and agreeing like flies on [censored]. It's amazing ... really quite comical actually.
You dispute everything I say on a totally conceptual level ..then concede to it in another post ..then argue against it in another. Back and forth. Now you're retreating into the sanctuary of ultra high volume (yes, with your beloved hot oil added in there too).
So ..essentially, you're going to jerk back and forth endlessly ..post your charts to make points that you later don't mean ..
..etc..etc..etc.
GOD LOVES YOU, SOUPY!!!!!!
I only dispute the concepts you can't grasp, and the ones you contradict yourself on ... I notice you don't seem to address those, but just ignore them and let them slide by. There is much that we agree on ... in case you haven't noticed.
The real problem with our little debates is that you can't comprehend what's going on half the time in these discussions. I'm sure other people with a more technical (engineering background), a better memory and a longer attention span can make it all out just fine.
BTW ... I can always tell when your are smoked and getting your arse whipped when you start going off track with your stupid nicknames and other moronic antics.
..etc..etc..etc.
