'05 Accord 2.4l with 165,000 miles
Since new, I've been using M1 0w-20 with OCI at 5k. Never consumed any oil... 4.5 qt out and 4.5 qt in
Threw in TGMO about 1,000 miles ago. All highway runs at 65/70 since the change
Checked oil yesterday and between strong sunshine and clean oil, I have to admit it was difficult for me to determine the level but I THINK I may be down close to a qt.
Will confirm but let's assume that's correct - that I am down a qt
Could a change in oil brand cause some form of consumption?
If so, any idea as to why this might occur?
Is this a cause for concern? Get myself ready to change PCV or any other preemptive measures?
The 06 Odyssey (63k on M1 0W-20 since new) absolutely loves TGMO, so I expected to notice a difference but I didn't expect this
Again, I could be wrong about the consumption and will confirm but I'm fairly certain I'm correct and it's low
A few more comments:
*. Same Wix filter as per prior OCIs. This time, however, I partially filled the filter prior to installation
* 2nd dose of MoS2... Only 1/2 can this time
*. Reason for switch from M1 to TGMO: Lighter at start-up with higher VI
Thanks for any input
