This tread his heading towards complete blather.
The old Volkswagen Beetle didn't even have an oil filter(junky screen), and there are still a LOT of old Beetles running around.
IMO, change your oil regularly, use a decent oil filter, don't let the engine overheat, and the engine will more than likely far outlast the body.
Jim Allen mentioned he had one of those old Beattles with just a screen and no oil filter. Guess what, the engine needed a rebuild at 75K miles.
I highly doubt an engine would go 250K miles like they do today with no oil filter on them, unless you changed oil every 2K miles. You could use your car for this test and let us know how it comes out.
My father bought an early 60s Beetle in the early 70s. He had the thing for about 8 years. He sold it and it still ran great. It had over 75K on it and no engine rebuild.
Just because one Beetle needed a rebuild at 75K does not mean ALL of them do.
The way this thread is going, unless you filter out particles > 2 microns in size, your engine is doomed.
Just because it appears to "still run great" at 75K doesn't mean it might have a lot of wear on engine parts.
I've had plenty of engines that still ran OK and seemed to "run great", but they were on the verge of a needed rebuild.
IMO, oil filters (and of course regular oil changes) do help keep wear down. Like I said, if you don't believe it then cap off the oil filter mount on your car and save some money on filters.
Nobody said filters had to filter everything out 100% to help keep wear down. Drama factor is going up in this thread.
I never said I don't believe oil filters work. I am trying to say that people are overreacting. I personally think that particles too small to be filtered out by a conventional oil filter are essentially harmless to an engine. If they were so devastating to an engine, manufacturers would have better oil filtering methods.
How do you filters out the engine dooming particles between 1 and 20 microns?
