Oxygenation and detergent are different things.(some chemicals could perform double duty I suppose)
I think at the end of the day I will just need to ask the gas station selling Rec-90, if I ever find one. It may be a generic term that varies from region to region.
And until then just warn others that just getting an "ethanol-free" gasoline may be no better than buying a food that advertises "no high fructose corn syrup" while just substituting more sugar, empty calories either way. That is depending on intended use, of course, my main reason for avoiding normal gasoline is for seasonal storage reasons so I would like no oxygenates of any type. While a boat owner may use the fuel quickly and want ethanol-free purely because of moisture issues.
Some in the recreational marine industry even consider ethanol to be a plus because it helps mix water that accidentally enters the fuel system. Not sure if these systems are sealed though. I remember once renting a boat with an outboard motor in Lake Tahoe, and we were having problems with it not starting well. The employee of the boat rental place showed us that the gas cap was on too tight and said that it had to be slightly open to ventilate. So I guess with that kind of setup, it wasn't terribly well protected against water/moisture ingress.
MYTH: Ethanol-blended fuels are bad and should be avoided.
TRUTH: Ethanol blended fuels (E10) are common throughout much of the United States. After the transition period from non-ethanol fuel, E10 may actually be a superior marine fuel, as it tends to keep low levels of water moving through the fuel system, keeping the system “dry”. For over a decade, marine engines have been engineered to handle E10 gasoline. However, all types of fuels should be treated if they won’t be used in a few weeks.
