Favorite Oil Brand for OPE
What's your guys favorite oil brand for OPE that is available in 10w-30 full synthetic (Mobil 1, Supertech, Quaker State, Pennzoil, Valvloline) and Amsoil is not worth it for me, so if that is your favorite, what is your second favorite brand?
What ever left overs I have sitting around. Never had an oil related issue. YMMV
Summer use equipment: Rotella T 15w40, Supertech 15w40, Napa 15w40
Snow blowers: Pennzoil 5w30
Year round use equipment (generators, garden tractors with winter chores, etc): Rotella T6 5w40, Rotella T5 10w30, Castrol 0w40
Delo, Delvac, Rotella T5 15W-40
Mobil 10W-30HM for log splitter (mostly run in winter)
Mobil 15W-50 occasionally - (have some left over)
My current fill is STP 30 weight but the next round will be a mix of the STP and some B&S oil I spied on the clearance rack. My favorite is whatever 30 weight is on sale.
My JD 425 has one of the following in it at all times. I've not been a fan of syn in this application because I don't think it's all that necessary. Nothing wrong with using it, but I don't see a benefit. Although I haven't used it yet, JD makes a fine 15w40 in it's Plus II.
Chevron Delo 15w40
Super Tech 15w40
M1 HM 10w30
Valvoline red jug 15w40
Chevron Delo 5w40 (syn is not a priority with me)
Valvoline Premium Blue 15w40
I buy jugs of whatever conventional oil is on sale and that usually lasts me years. Right now, it's Valvoline conventional 5 and 10W30. I used to use whatever was left over from my vehicle oil changes. For everyday residential duty, a SN rated conventional oil is overkill. Just change it regularly.
Delo 15/40 for zero turn and M1 HM 10/30 in the others. Once the M1 HM 10/30 runs out it will be any 10/30 syn on sale.
Keeping clean oil and correct level means more than if I use a 15/40 versus 10/30.
I use Motul 300V and change oil/clean air filter after every mow. My weed whacker and chain saws run exclusively on Motul 800 jetted for 32:1 with new spark plugs and top ends annually. Powered yard equipment is no different than any other engine used in extreme conditions.
First time I've seen anyone use Motul in lawn equipment.
