\Well, I didn't say Castrol was "worse".
You didn't?
The Edge is worse, because I can buy Mobil 1 EP at Walmart and get a $12 rebate making it around $14...
Comparing AP to Edge Extended is not apples to apples--Mobil EP would be the appropriate oil to compare.
Sure, and EP still has a lower pour point and strangely Mobil 1 EP seems to have pour points corresponding with weights with their 0W-20 around -65F, and yes, the -40C 5W-30 weight. So perhaps Mobil is more honest or upfront and Castrol seems to be CYA'ing?
M1 EP 5W-30 has a 1° C difference in pour point versus Castrol 5W-30--hardly a vast difference, but factually yes, a 1° C difference is less.
Other than price delta (which is fully dependent on a rebate because at normal prices, both Castrol and Mobil flip-flop on who is higher),
I would confidently say that Castrol almost always higher, even before rebates. But that's not really much of a defense of Castrol since again, they don't do rebates and have even taken the Promotions tab off their website...
Perhaps in your locale, I have seen the switch up regularly, in fact on Amazon right now, it would take a Mobil rebate to come close to the price of Castrol.
they are very similar in quality and performance.
Depending on which lineup, Castrol is using Group II+ marketed as full synthetic, albeit certainly blended with III and probably some V. It seems they have very unbalanced lines at premium price points with some oils such as nearly all of the 0W-XX having significant POE/PAO and then having some very bland offerings in the typical American weights that seem to offer little over say-Pennzoil conventional. That's a fair point of criticism, as Castrol's closest competitor to AP is their "Professional" line in the US, which is very difficult to buy at at reasonable price point for an average consumer.
What are the differences in real world results? I have not seen any UOA here that shows any major synthetic out perform another to any large degree.
In the end, you come across as sounding bitter over a failed rebate versus objectively comparing the quality of the two oils.
And you sound like a bit of a hypo'wit fanboi for taking things out of context and ignoring the actual post I responded to, with some dolt interjecting a non-sequitur that had nothing to do with the thread topic. And no, no "failed rebate". I mean, read the thread topic?
Laughable since I use Castrol, Mobil, and Pennzoil. I took nothing out of context--I quoted you exactly and there was nothing non-sequitur about about my response to your post. Last, but not least, I am fairly that your expletive laced comment about a rebate was in your OP; perhaps I misunderstood your intent, but then again, I tend to ignore sarcasm from those who need to use those types of words to make a point.
