Hide it out in the desert. Report as stolen.
Thankfully I dont deal with customers much and this problem is not my problem.Turn this situation over ASAP to the foreman/manager/owner. Be ready to explain what you saw but you nor the other mechanic should be the first line of defense on this issue.
With that many miles and already making a noise the customer should accept it as such. No hard sell involved if you are working an honest business.This is obviously a coincidence, but it's going to be a hard sell to the customer that the shop did nothing to cause it.
I'm pretty knowledgeable and I would find it hard to believe that the engine just happened to destroy itself after I brought it to the shop.
Sunshine, lollipops and rainbows?With that many miles and already making a noise the customer should accept it as such. No hard sell involved if you are working an honest business.
100% this.If it were my car, I would be both upset as well as suspect.
Now, my maintenance practices are probably much better than those of this owner.
And I am usually the first one to notice any abnormality in either function, or sound.
A slight ticking noise that usually proceeds a failure, would’ve been noticed.
But, put simply, if I brought you a running car that wasn’t making any noise and you told me that it spontaneously “blew up“ in your shop, I would blame you.
I would be asking just what the heck you did to that poor car to make it blow up.
They will just refer to the most commonly stolen vehicle list …Hide it out in the desert. Report as stolen.
This would cover it - presentation is key in this instance.It came in running bad and you were diagnosing and repairing the problem. Engine threw a rod. Found the problem. Whether or not the customer believes the 2 of you is a different story. Now you get to find out what caused the quick exit of the rod to explain to the customer.
