quote:
Originally posted by Red Bowtie:
A few more observations on the filter and a reply to some comments.
The filter media appears to be quite durable. There were no tears found. It just appears to have gotten pushed through the wall of the Ecore and into the outlet, which apparently reduced the flow of oil, which led to the bearing failure.
So if I understand this correctly, a functional bypass would have prevented the Ecore collapse and would have allowed unfiltered oil to circulate back into the motor. Just how much oil can a bypass flow anyhow? Enough to save the bearings? Just looking at the bypass hole, it doesn't appear that a whole lot is going to flow through it. Based on those observations, I'm not buying that a functional bypass would have saved anything in our situation. A blocked bypass and a solid filter that doesn't collapse under moderate pressure still works for us. Why would circulating unfiltered oil not contribute to a death spiral? Especially through a restricted orifice like a bypass valve?
