- Joined
- Sep 28, 2002
- Messages
- 39,793
He could have had substantial flow reduction before the element collapsed, imo. The time frame isn't too much of a factor when you're at 5000 rpm. You smoke up whatever static oil is sitting there ..plus any that may be pumping. Once the flow is reduced and the temp exceeds the ability of the refresh rate to cool it (so it stays what we consider oil) ..you're history after any AW layer is burned off. This wouldn't have much of a time frame to it.
That is, the center cage could have been intact and the engine could have been toast already ..but the events would be so close together that it really doesn't matter, imo. If the center cage was made of titanium and the media of kevlar ..the same thing could have occurred. Once the pump is in relief there is no assurance of any oil flow (although there will typically be plenty with a bypass)
