- Joined
- Sep 28, 2002
- Messages
- 39,793
Not necessarily so, Winston. It would be extremely rare ..but by no means impossible. That's the pressure differential that Champ reported that was required to break the center tube.quote:
Originally posted by Winston:
One final clarification. The 72psi that is seen at cold startup is not the differential pressure across the filter. The differential pressure across the filter will be much less than 72psi.
I would bet the max differential pressure required to collapse the center tube on Wix's filter is probably double that on the Ecore.
Metal tube/center wells are no where near as strong as the Ecore's. You can flatten them by stepping on most. The spiral wound center tubes are more resistant to collapse then the straight seamed type ..but they will still crush before an ecore. The problem with an Ecore is that, when it breaks, it factures and potentially fragments. Something that a metal tube will not do.
