Not when it's false slander. Some need to work on their so called humor.
No slander, all in good fun. If I didn't like you, I'd just ignore you.
Some must be wearing devil glasses that make them say everything backwards. Don't play your LPs backwards.Wavy pleats are the devil. Read it in your book.![]()
I'll keep correcting you tooLoL, yeah, it looks ok. I'm just returning some of the so called "humor jabbing". But you better check it for wavy pleats after use.![]()
I'd rather you put me on ignore than try to twist up what I've said, because it doesn't really come across as "humor". It comes across as trying to claim I've made certain claims that I haven't made. I don't find that funny.No slander, all in good fun. If I didn't like you, I'd just ignore you.![]()
I have so many that I'll never use grinLoL, yeah, it looks ok. I'm just returning some of the so called "humor jabbing". But you better check it for wavy pleats after use.![]()
New stock S241...
The can is thick and exceptionally strong..
Just under .025" thick
Rock solid filter. This 10K filter is a better filter in all respects to the 20k K&N Select from my cps.. I prefer this over the Fram TG as well.
The powder coating is perfection. Under $7 on Amazon last week.
View attachment 210433View attachment 210434View attachment 210435View attachment 210436
New stock S241...
Yeah, just like you implied I said "High quality" on torn Purolator's. You know as they say a taste of your own...I'd rather you put me on ignore than try to twist up what I've said, because it doesn't really come across as "humor". It comes across as trying to claim I've made certain claims that I haven't made. I don't find that funny.
One's sense of "high quality" might be skewed by fanboyism.Yeah, just like you implied I said "High quality" on torn Purolator's. You know as they say a taste of your own...
Thank you AdamNice work Jim. I see they still use Steele madcap’s. Nice photos and info![]()
$7 dollars & metal end caps sure beats the socks off of "fiber" end caps that TG probably employs. Nice pics.![]()
The media on this Ecogard has been assembled and glued nicely. It is rated at 10k miles while a Tough Guard is rated at 15K. Any thoughts as to why? Is it the media density that controls filter life or the type of media? Thank you.New stock S241...
someone correct me if i'm wrong, but its to do with the holding capacity of the filter. mileage ratings are a sensitve topic because 15k miles on a spotless motor with a high quality synthetic is very different than 15k miles with generic motor oil in a sludged up motor.The media on this Ecogard has been assembled and glued nicely. It is rated at 10k miles while a Tough Guard is rated at 15K. Any thoughts as to why? Is it the media density that controls filter life or the type of media? Thank you.
Yes, the "up to" mileage use rating is connected to the holding capacity. "Up to" implies the best case scenario, so if someone thinks it can do the "up to" mileage rating on a dirty sludged up engine doesn't quite understand.someone correct me if i'm wrong, but its to do with the holding capacity of the filter. mileage ratings are a sensitve topic because 15k miles on a spotless motor with a high quality synthetic is very different than 15k miles with generic motor oil in a sludged up motor.
When Motorking was active here, he explained how Fram bases the "up to" mileage use rating based on the holding capacity - iirc, he mentioned a worse case of 1 gram of debris generated per 1000 miles for a typical engine. I'm betting a well taken care of engine produces way less than that, and the "up to" rating is probably more based on a typical "clean" running engine with less than the 1g/1K rate. Fram and other big filter companies most likely do some field testing to collect some real world in use data.Only other factor is marketing, you see if especially with Fram.
I have PG's from both Vietnam and China and I can't tell the difference between them quality wise. A trend that has also been supported here with C/P's.I
OMG! Is everyone supposed to hold hands and cry now?I'd rather you put me on ignore than try to twist up what I've said, because it doesn't really come across as "humor". It comes across as trying to claim I've made certain claims that I haven't made. I don't find that funny.
LoL ... people need to read better and stop playing games and twisting things around is more like it. Just like you having a bad memory that distorts what you "think" I said 10-12 years ago.OMG! Is everyone supposed to hold hands and cry now?![]()
Not doubting any of the spot on posts above but personally I think PG-EG are playing it safe and smart.The media on this Ecogard has been assembled and glued nicely. It is rated at 10k miles while a Tough Guard is rated at 15K. Any thoughts as to why? Is it the media density that controls filter life or the type of media? Thank you.
