Originally Posted By: fdcg27
I've always done it exactly that way.
Drain it cold and replace the volume that you drained out.
It's not as though a couple of ounces either way are going to matter and it's not as though a dipstick is a high precision measuring device anyway.
That's why I always get a chuckle out of guys who make sure to top the oil off until it's exactly at the full line on the dipstick.
The full line in any two identical engines will not correspond to exactly the same volume of oil.
The dipstick is too imprecise a measuring tool.
It's merely intended to keep the tranny or engine within a safe range of fluid volumes.
If checked using the same method each time, the engine oil dipstick in the my two previous Subarus, as well as my wife's previous and current Civics have always indicated full after adding the same amount of oil during an oil change.
The 97 legacy and Civic's ATF dipstick also indicated accurately.
Unfortunately, my new Subie takes an odd quantity of engine oil, so I can't dump in a 5-quart jug and call it good - i need to part of a sixth quart and check the dipstick, which for some reason is not very easy to read. The other Subies left a solid termination of oil on the dipstick, but this one seems to smear.
I guess my point is, a dipstick is pretty darned accurate, since, on level ground, it reads to the same depth into the pan each and every time - what's more accurate than that? What screws things up is us, changing how we measure, from full operating temp to slightly warmed up, and on level to sloped surfaces.
I agree with you that a few oz. won't matter much, but the difference between full on the dipstick and somewhere closer to the "add" mark can be upwards of a full quart. It usually doesn't matter even then, but more oil, at a level closer or just over full on the dipstick will add a margin of safety for unintentionally long intervals and in vehicles that consume but are not replenished.
