Which Lubegard additive to use with ATF+4?
Winnipeg MB CA
I've been thinking of adding Lubegard to the ATF+4 used in our 2007 Dodge Grand Caravan w/ 3.3 and 4-speed AT.
No driveability issues, simply wanting to keep the transmission as healthy as reasonably possible.
Shortly after we bought the van almost four years ago, I replaced the transmission oil pan with a pan with a drain plug. At the time of the pan replacement, I replaced the filter.
That was at 199,000 km (c. 124,000 miles). We're now at 265,000 km (c. 164,000 miles), and I've done several drain-and-fills. Each drain is about 2.5 US quarts.
For the first fill (with the pan drop) and several after that, I added Castrol synthetic ATF+4.
I couldn't find the Castrol last time, and bought NAPA-branded ATF+4.
So why do I want to add Lubegard?
If the transmission fails, the cost of a repair would likely exceed the value of the van. It's not worth much, but has served us well, and I think will continue to, barring a major mechanical failure. It would be good if it lasts another couple of years, to get us through the grandchildren's multiple-car-seat era. I figure the Lubegard would be cheap added insurance, and will buy me some peace of mind. (I probably don't actually have to justify this to the BITOG crew.)
So, which Lubegard product would you recommend for my application?
Thanks!
panthermike,
Doesn’t LG Platinum add more friction modifier than one might need when using an OEM type of ATF(other than Dexron/Mercon), that already has its FM added in?
That’s my thinking anyway.
I just dumped a full bottle of Red into a 46RE today along with a spill 'n fill. Did it do anything? Probably not, but it seemed "fine" on my test drive. The owner says it was "slipping" before but I don't know what that means to her.
panthermike,
I've heard Mola talk about this before and honestly I'm not sure if it's problematic or not. I've done probably 200k miles cumulatively with the Plat and no issues. I definitely don't overdose it though; 1oz/qt or slightly less. LG says that platinum can be used with any ATF. There are several members here that run it as well with no concerns, I believe @ctechbob might be one as well?
I would get some AMSOIL ATF or even better, Red Line C+ ATF and don't use any additives. I don't believe in snake oil. Use quality parts, and save yourself the hasttle.
Yup, for roughly 50k now in my 10R80 with either Motorcraft ULV or Valvoline ULV (Whichever I can get cheaper).
--Edit--
At 1oz/qt.
