Does the Diesel engine flush actually work?
Originally Posted By: meep
not aware of the vehicles history, any dramatic flush you do should be followed by clearing out whatever it breaks up, as it could clog the pickup if it's severe. So you might as well just take off the valve covers and scrape the stuff out without chemicals, and if you are really enterprising pull the oil pan and clean it too. No liquid solution will beat this. THEN run short OCIs with seafoam or the cleaner of your choice and enjoy the vehicle.
Not too long ago BITOG was all over some other product, maybe "kreen"?
-m
I already have a new oil pan and Melling standard pressure oil pump + pickup tube to install because of a severely rusted oil pan after 20 years of road salt. I have good oil pressure, but might as well replace it when I pull the pan because it has obviously led a rough life and I plan on keeping this truck for a long time.
Originally Posted By: Delta
Couldn't you just get something like the Liqui-Moly Engine Flush treatment or the like and be done with it? Seems it would be easier and safer doing it that way.
Are you flushing because of noisy valvetrain/internals or just a piece of mind thing? Honestly if it's quiet I'd just do shorter OCI intervals and be done with it.
This is good advice, Maybe some Pennzoil Conventional or ST short OCIs would get it cleaned up eventually. How many short OCIs would you run a single X2 Fram Ultra before changing?
Originally Posted By: andyd
First you hafta need the flush. Most BITOGers keep their engines clean enough not to require a flush. I have never felt the need myself. However if I was presented with that Cobalt, I wouldn't hesitate.
Trust me, this thing would be spotless inside if I owned it from new.
Sludged engines has to be top 5 most popular topics on this board. I love me a filter C&P when you know the engine was bypassing the filter for a LONG time!
Remove the valve covers and spray the valvetrain down with Berryman B-12 Chemtool and let soak. Fill the block with the same and acetone mix in if using 100% Berryman is too expensive. Let it sit overnight and drop the oil pan. Spray down the internals and you should be as clean as possible. Run two short OCIs after that and it will be done.
