I have a 68 camaro with what I believe to be a Mark IV 454 engine from a late 70's - early 80's vehicle. I believe that the dipstick currently in the engine is wrong (TOO LONG), as it indicates full oil levels when the oil is actually significantly low. Does anyone know the correct length of what a BBC chevy engine dipstick from this era should be?
The car holds approximately 5 quarts, and the dipstick read full prior to an oil change yesterday. The car was on a lift prior to draining the oil, and it appears only 2 quarts or so exited the oil pan. I couldn't believe it. I ran a new quart of oil through the crankcase with the drain open just to verify it was flowing freely, and it was. The car simply had only 2 quarts or so of oil in it, even though the dipstick was indicating full.
