I have an elderly Ford Y-Block that has been overhauled with a hone and cast rings. I'm using M1 15w-50 and it uses about a quart in 1,500 miles, and I can see it on some of the spark plugs. There is no smoke, no leaks and the engine runs really well.
Do you guys think the characteristics of synthetic oil would allow it to leak past imperfect rings/ cylinder bores easier than say a Delo 15w-40? I am thinking of changing the oil now that it's about a quart low.
I do use the truck pretty hard- I just took a trip over Sonora Pass in the Sierras (up to 26% grade) with a 1,500 pound camper. I had to run it pretty hard to pull that grade. There have been several other passes this OCI that have been over 9,000 feet.
Should I try the Delo?
