Dodge Durango 3.6L - HPL CK-4 5w-20 - 10,474 miles on oil - 184,710 miles total
wwillson
Staff member
Colorado
This sample is from the Durango that I used to own. I sold it to my Son and DIL, with the understanding that I get to maintain it. They were somewhat confused and when I told them I want the data for BITOG, they gave me an odd look. Go figure. Their driving habits are much different than mine. They do a lot of short trip driving, while I did a lot of long trips. It will be interesting to compare how short tripping affects the oil compared to long trips. One sample is no samples, but the first short trip sample doesn't look much different.
Previous UOA here
Google Docs spreadsheet here for entire UOA history
Edit: I removed the first OCI because the embedded table is getting too wide. See the google spreadsheet above for the data from the first OCI.
Edit: Filter pictures added 11/18/2024.
This is a Fram Endurance that was in service for 10,474 k miles. When you cut one of these apart, it is easy to see that this is a high quality filter. The seam where the filter element is joined together is hard to pull apart, unlike the Ultra which practically falls apart if you look at it. This engine continues to shed carbonaceous material from the pistons, but at a much lower rate then previous filter runs. I think 10k was about the right interval in this engine for this filter. There is a normal amount of metal in the filter for a 10k run, which is more than a little and less than a lot. The amount of metal is on par with what we've seen from this engine in the past. Yes, those shiny specks are metal flakes.
Data:
Sample Information
Sample DateMarch 15, 2022September 5, 2022April 19, 2023June 13, 2023October 28, 2023January 1, 2024January 9, 2024Sept 22, 2024
Machine Age miles141,500147,000152,000158,700168,000173,300174,236184,710
Oil Age miles1,5007,00012,00018,70028,00033,3005010,474
Makeup oil quarts0.750
Filter Age miles1,5002,0005,0006,7005,0005,0005010,474
Oil Changedyesnonononoyesnono
Filter Changedyesyesyesyesyesyesnono
BrandHPLHPLHPLHPLHPLHPLHPLHPL
Viscosity5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO
new formula
Wear Metals
Iron6915172333419
Chromium<1<1<1<11201
Nickel<100<1<1<10<1
Titanium<1<10<1<1<10<1
Silver0<100000<1
Aluminum2415812710
Lead10003<1<10
Copper316572696465854
Tin<1000<1<1<10
Vanandium0<10<1<1<1<1<1
Cadmium00000000
Additives
Boron2200116184
Barium00041000
Molybdenum492548600590494573579581
Manganese<1<1<1<1<12<11
Magnesium10919811158105999811311008974
Calcium24312458276726452340263725322545
Phosphorus109410241095104185510891144910
Zinc11761271141112711129140412841194
Contaminants
Silicon1213181720221320
Sodium03541619414
Potassium022343<13
Fuel %<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0
GlycolNEGNEGNEGNEGNEGNEGNEGNEG
Soot%0.10.10.10.100.10.10.1
Fluid Condition
TBN16.810.89.288.1167.7615.038.94
Viscosity9.41010.411.612.613.210.410.4
Oxidation0 (39.7)12(51.7)14.3(54.0)21(60.7)24.4(64.1)27.1(66.8)0(39.5)15.5(55)
Very good report for the new driving habbit's. I could imagine the funny look in response to the oil change maintenance request.
Around 15k would be the sweet spot on this oil/vehicle. But I have no idea on the direction your kiddo's want to do or how often you want to change. I see they're about 10 months into this interval so 1 full year would be perfect with a bit of a buffer leftover at around 12,600 miles (1 yr based on these numbers),.
I'll change it when the data says to change it and not a UOA sooner :)
This HPL oil is formulated for extended drains and as you can see from the past intervals that I'm not afraid to extend. I'll check it at 20k miles and see how it's doing.
Wow, looks surprisingly good! Did it use any oil?
Edit...I see 3/4 qt make up oil.
No, you need to slide over two more columns. Maybe I will take the first OCI out, because the table is getting too wide.
Previous UOA:
Edit: I removed the first OCI because the embedded table is getting too wide. See the previous thread above for the data from the first OCI.
Data:
Sample Information
new formula
Wear Metals
Iron6915172333419
Nickel<100<1<1<10<1
Silver0<100000<1
Aluminum2415812710
Lead10003<1<10
Tin<1000<1<1<10
Cadmium00000000
Additives
Boron2200116184
Barium00041000
Contaminants
Sodium03541619414
Potassium022343<13
Fluid Condition
Wear was good. Love the Moly, but the oil is thickening out of grade.
  • Like
Reactions: wlk
The 5w-20 started at 10.4?
Yes, remember that there was still some of the previous run's oil left in the engine. The previous run ended at 13.2, hence the increased viscosity of the 50 mile sample.
This was very enjoyable to read and you made the data crystal clear - thank you for that! We have a 2014 JGC 3.6 in the fleet so I may consider the HPL but then again it's been on a diet of Mobil 1 5w/30 it's whole life (171k) so maybe I should not change anything at this point. It still looks and drives like a new car.
Looks like a 30 grade from here. Formulated on the margin.
What is the virgin KV100? That 33K run was too long.
Interesting lube.
Any Fuel mileage hits with no VM?
Have the cam finger followers been replaced at some stage in this engine?
Thanks for the data.
Nope, this is from the same lot # as the previous OCI, which started at ~9.0. The thickening is likely from being blended with the higher viscosity left over oil in the engine and/or lab error, probably both.
Too long for what? All evidence I have presented in my previous threads shows that the 34k run caused no problems.
By "VM" do you mean viscosity index modifiers? If so, this 5w-20 HDEO has VIIs.
No, the valve covers have never been off.
Very well, I was going by the si level of the last run but I see you've went to 33k already and silicon has not gone up hardly at all. I thought you'd mention dusty area in your other UOA so I had silicon in mind (20 ppm @ 10k) but this situation may be different. Carry on. 💪 😁
Excited to see future results. 😁
Keep in mind the Si has only gone up 7ppm or 0.7ppm/1k miles in this 10k run. That's about what it was during the this entire test across many UOAs, so I call it normal.
