I have 2 Fbodies one with a V6 and an LS1. On my LS1 the overflow bottle was empty and the radiator was full. On the V6 the overflow bottle was empty and the radiator was a bit low. The V6 may have some small leak around a hose which might be an explanation. Both have a vented overflow which allows air in. Is it possible that the hot coolant in the overflow along with engine compartment heat could be allowing the water in the overflow to evaporate. This might also explain why the overflows get the gunk buildup over several year intervals.
Now, this is a pattern I've noticed with other vehicles as well. I had a New 94 Mustang that needed coolant added every year.
