My Random Thoughts on Keeping a Car Running for a while
I have a 2015 F-250. Been treated with a couple of sprayed rust proofing products over the years. Now in DE it's hard to find someone who sprays the rustproofing products. I work from home so I try and avoid driving the few times when the roads are salt or brine treated. I just upgraded the HPFP. Keep up with suspension and brakes. Get outside detailed 2x a year. Don't let wife or kids drive it. Don"t get into the vehicle with screwdriver or putty knife sticking out of back pocket (did that in another vehicle and you can guess the result).
I like to keep the vehicles I bought brand new for a long time, but honestly, outside or regular maintenance and your willingness to keep it, there is no formula for the long term ownership.
There are just too many variables to account for. Your perfectly maintained and babied car can be totaled by an uninsured driver tomorrow. No one will care, especially your insurance company that it was your “baby” or that you waxed it once a week and changed the oil from the premium shelf at Walmart.
I know that some guys like to worry about their cars all the time and that’s how they “enjoy” the ownership, but man, that sounds exhausting.
Stabil or use ethanol free gas if storage is of a longer time period.
Remove the alternator from the vehicle and either sell it or keep it in climate controlled facilities if put into very long term storage
Replace valve cover gaskets around 100k or at the first sign of failure. The hoses and stuff are chemically incompatible with motor oil aerosol. .
You are going to have to explain this alternator idea. You can leave it in forever, and replace when needed years down the road. Do you believe that it degrades and causes further damage?
Don't drive the car in the rust belt seems to be the best way to make the car last.
My engine can last X miles!
Good for you.
My seat just fell out of the bottom of my car when I got in it too vigorously. But yeah the engine is a great.
I left alternators on old cars that didn't run for two-three years. These cars were not garaged. So things got stuck over time, even the exterior locks took time to loosen up again. When time came to fire them up, the alternators were dead.
My suspicion is simple. Heat from regular use prevents water vapor from infiltrating and causing some form of chemical breakdown on the voltage regulator internals, the diode material, and even maybe breaking down the wiring varnish.
I had to eat one getting stranded on a main road, and then it got towed because I wasn't close by in order to get cell service. The company also dented the hood.
Maybe the advice should be to make sure things are mobile when you start up. On pulling and selling the alternator as advice, you got nuthin
I'm barely understanding what exactly your point is or what are you trying to say? What is the meaning of "things are mobile".
Nor did I say anything about selling the alternator.
Or are you saying I'm lying and my story is fiction.
Not saying you are lying. I encourage you to look at the second line of your post#35 which interpreted wrongly due to the poor sentence construction using an ambiguous antecedents. I used the word mobile to describe non- binding, freely moving components. Whatever you were suggesting about removing the alternator is ignorant advice
Indeed, learned a new word today...
but I read post #35 the same way. Store the alternator well, or sell the alternator.
Shame on having to replace an alternator on the side of the road. Did it seize or just fail?
Antidotally... few years ago on my daily driver (a car that I would drive 50 miles to work, then 50 home, 5 days a week, plus trips on Saturday & Sunday), I had noticed that the radiator tank (fiberglass) was cracked and showed signs of weeping. Ordered a radiator on Wed, swapped in on Saturday. After getting in I noticed... the battery light was on. I had driven it the day before! but it didn't care, alternator died that day.
No sooner did I get the alternator swapped that the cable running from the shifter to the transmission snapped. Three quick repairs, I think it was down for 3 weeks (lost two as I tried to go cheap and order replacement brushes for the OEM Denso alternator--wasn't that--then it was a few days to get the cable in the mail).
Good tips. Don’t follow oil change OCI or fuel.
I use 10k interval per VW and at 190k no issues.
I worked on off brand gas station in college. We bought ends of tanker trucks including premium sometimes added to our regular tanks from branded stuff like Mobil , Shell , BP etc. All trucks went to same depot in Boston but each brand had a tank or so.
Do you use ACEA oils?
