I've changed my oil every 4 to 5k, it makes no sense to dump out oil that still looks new. If it goes bad sitting then what I'll put in it isn't any newer. It all came with the truck or was bought in bulk at that time. The same with the the Motorcraft coolant that everyone says to get rid of.
When I got the '03 I let the dealer do the first couple oil changes since they were 'free' for the first 5 years. It was not the dealer I worked at, they had been gone for some time by that point.
Synthetic options were still scarce for diesel oils then and the only oil I was able to find then was Chevron Delo 5W40. I have 6 20 gallon barrels of it bought in 2008 or 2009. Buying that amount made it cheaper than buying half as much oil by the case and they gave me the pump and the measuring buckets to dispense it. The thought was to avoid paying the dealer $185 per oil change. When I bought the truck I had them include 12 cases of oil and 24 oil and 24 fuel filters. The hard part was lugging those barrels down the basement steps for safe storage and back out again when I moved, twice.
The truck hasn't seen any hard work in its life, a few loads of stuff moving but household stuff and a few tractors and tool boxes isn't any serious work for any truck.
The oil in it still looks new at 3,351 miles. I would also think that with the synthetic oil the oil changes can go a bit further.
If I go by time not miles, then last year the truck got zero miles, it sat from 3-22 to 1-25 because I was at my other house and have been using the older truck more lately. The only reason I drove it three weeks ago was to go get new tires for it. The spare set were getting pretty dry rotted looking so I replaced those and bought a new set for the truck as well since those are original as well. I really hate to take off the OEM tires since I can't buy them new anymore, The only tires I could find here were Cooper AT3s in ten ply, all the BFG's were made in Israel and China and we had a ton of issues with them at work a few years ago. I had to hunt for a month to find Cooper tires that were still US made since they too sold out now. The set I found were made in 11/2019 and I had to have a buddy pick them up in WV. I mounted the spare set up last night on the new rims, I'll do the truck when its warmer out.
I drained the coolant and did my own inspection and flush then at around 1,580 miles in 2008 or so. I drained the coolant, which looked new yet, removed and flushed the degas bottle and flushed the block at work using the pump that they use for the big trucks. I found that if I raised the rear axle 5ft the coolant system would drain competely minus what ever may remain in the egr cooler area. It got flushed for 40 minutes and drained. I ran the original coolant through two filters, and added two gallons of fresh coolant to the mix first and refilled the truck with the original coolant ending up with about an extra gallon.
I drained off about two gallons from the bottom block plug and radiator drain twice over the years and pulled and flushed the degas bottle adding new coolant each time to refill it when I replaced the ECP sensor once at 5k and again at 9k)
Never has the coolant shown as being weak or discolored in anyway. I bought an aftermarket coolant filter kit years ago but never installed it. I didn't like how it tied in and didn't want to do it until or if I changed the coolant to red,
The trucks at work ranged from 5 to 20 years old. The coolant never got drained and replaced, it got 'replenished' or recycled through a machine that would filter and reuse it. Those trucks, mostly International and Freightliners, ran for over a million miles. The two engine failures they had were driver or mechanic caused. One engine overheated after a bypass hose split open that was just replaced. A brand new hose split open. The driver continued to drive till he cooked the engine and cracked two liners and the timing cover. $11k later all was fixed. The other failure was a bad degas bottle on a VT365 in a straight truck.
It lost coolant, the driver kept driving despite being told to wait for a tow and thus cooked the motor. They parked the truck and it became my new storage shed. Due to its age and miles they just chose not to fix it. It drove here but it took about 200 gallons of water to keep refilling it. Both heads are leaking water out the rear lower corners of the head gaskets. I just parked it out back, built a deck and steps to the door and added trusses and an A roof so it don't look like an old truck sitting there.
What is the Motorcraft Gold A/F? I thought that was supposed to be OAT The bottles do not say, it only says its VC-7-B
I tried the Ohmeter thing and can't get a reading? I have a Fluke 23-III which also has a Navistar tool number on it.
Plus two Snap On MT565AV meters and several CE and Harbor Freight meters and two Radio Shack digital meters.
All read the same. Locked into the lowest range, (if not the meter just wandered up and down).
I get 7.48 ohms on my 03 F250 with the positive lead on the alternator bracket and the other in the coolant in the degas bottle.
Wanting to find a control I poured some fresh Motorcraft gold premix into a clean metal drain pan and tested the resistance to the pan through fresh coolant and got 14 ohms.
I then tried the same with the red coolant from the Supertech jug and got 8.08 ohms
I then thought maybe it being directly in a metal pan was affecting it so I grabbed a foil cup, the kind used to mix epoxy in and put 4 oz of red Super Tech in it and got the same readings on all of the meters.
I then wanted to compare to another truck. I went two doors down to a neighbor who just bought a brand new F450 6.7 dually. I did the same test on that truck, going from the front enging bracket to the cooant in the bottle and I got 9.19 ohms.
I then went back in the garage and broke open a new jug of Motorcraft green coolant that came with my '96 F350. The new green coolant gave me 15.81 ohms.
I don't think the test is valid in anyway. There are too many variables including temperature and brand of coolant.
Then I went back to the Supertech coolant. It ate through the foil cup which was inside a cut off Solo cup. When I picked it all up it had leaked through the Solo cup too. The cup didn't look melted but the foil was eaten away and fell apart like confetti.
