Difference between M1 0w30 afe and 0w30 esp?
Do the formulations have to be retested every time MB 229.52 is updated? I doubt it. I would think they are only tested at the time of the formulation.
They have to. All of them do it that way. When one gets a document that oil is approved, there is an expiration date of approval.
Mobil1 ESP 0W30 has been approved for MB229.52 for some time. When approval expires, MB won't issue new just bcs. the old one expired. Changes in approval, if there are any, must be addressed, if not, the manufacturer wants to know that oil formulation was not changed.
Besides that, that still does not means Mobil1 ESP was not meeting all these requirements even before test was introduced.
Pennzoil Platinum Euro 5W40 was meeting API SP requirements even before API introduced SP.
Lower calcium can just lower the possibility of an event. It is a bandaid.
And m1 0w30 esp is not a low calcium oil and not lspi mitigatin
What are the test sequences for 229.52 currently? I assume you have them.
Do the formulations have to be retested every time MB 229.52 is updated? I doubt it. I would think they are only tested at the time when the oil is first approved for marketing.
How much do you want to bet @edyvw @BMWTurboDzl @OVERKILL do not have the actual test sequences for the current 229.52.
Please tell me you are not relying on the only single public article on the internet that is a blog post from lubrizol not even the spec sheet for 229.52 to form your opinion on the current testing protocols of 229.52 and how m1 must list them on their bottles. Lubrizol doesnt even list 229.52...
https://360.lubrizol.com/Specifications/Daimler
https://www.oilspecifications.org/mercedes_mb.php
How long is the expiration typically?
OK< let me play this game.
What is a low calcium number, and tell us at what levels of calcium LSPI even occurs?
You still do not understand what ACTUALLY causes LSPI and what is LSPI.
Playing the game would be answering the question.
What are the test sequences and sorcs required to meet 229.52?
Well, the additive companies like Lubrizol, Afton, et al. are part of the consortiums who develop the oil specs, tests, and formulations along with the automotive OEMs; so, they must know about their own specs, tests, and formulations. ;) These additives packs are pretested and preapproved for blending. All the oil blenders have to do is to mix them with base oil and VII, and they get a plethora of automatic industry and OEM approval.
Afton and Lubrizol both say that an LSPI test was incorporated into some MB specs circa 2020; so, it must be done for newly formulated MB 229.52 oils but not for older ones.
I am guessing that Mobil 1 ESP 0W-30, like most other ESP formulations, have not updated to a mixed calcium–magnesium detergent yet; so, it does not comply at the moment with the latest API and OEM specs that have LSPI tests. It will eventually update/upgrade though, probably anytime now.
There is a four-digit formulation number in the date stamp on the back label of ExxonMobil oil bottles, which would tell you for sure of any formulation changes and/or differences.
Yeah. I mean there might be minor tweaks which are done anyway throughout lifespan of an oil. But anything major will result in new MSDS and pds too. I didn’t see pds of SP version, is it same as “older” one?
The PDS I linked above says,
• Mobil 1 ESP 0W-30 based on Mobil low-ash synthetic technology, meets or exceeds ACEA C3 industry standard to help protect exhaust-gas after-treatment systems designed to limit engine emissions. It also meets or exceeds API SP engine-test requirements to help address LSPI (low-speed preignition), making it a preferred choice for downsized direct-injection turbocharged gasoline engines.
Any change in the additive package should result in a change in the four-digit formulation number in the date stamp on the back label of the bottle. An allowed change in the base oil under API base-oil interchangeability guidelines and/or additive-company guidelines would not result in a change though.
It is same formulation. It didn’t update API approval on bottles.
How did it stay the same formulation but change viscosity and density?
