That seems to be the safest option these days, not only in here.I don't have to justify anything here, guys. Just sharing an experience. Next time I'll just keep it to myself. LOL.
Consider it a rinse cycle. Get some of the dregs out while getting some use out of oil I wouldn't have otherwise used.
Don't you think that is up to me to decide?Huge waste of time and resources.
I do. I'm well aware that dry capacity is much higher. Consider it the same principal as a brake fluid exchange without doing a full-on bleed. The idea is to replace some of the oldest fluid with newer fluid. You won't ever get all the old oil out, but you can reduce the percentage of old oil living in the system. But then again, I wasn't thinking that hard about what I was doing. I was simply getting some use out of orphan oil that wouldn't otherwise have gotten use.You realize there’s a good amount of residual oil left in the internals, right? So you’ll always have a “frankenbrew” effect. Now even moreso since you added 4 more oils that are now part of the residual.
For all the critics, I think this is legit. Minor cost in the grand scheme, and the oil did get used and serve a purpose; that was to help further clean and "reset" the engine internals to a far cleaner state. I'm a frugal person but not cheap and this seems like a good investment in time/resources for the OPs situation of extra resources (franken-oil and time).So this isn't something I plan on doing often, but the circumstances all came together to make it doable. I had just enough leftover oil of various brands and grades (3 qts) that I didn't have a use for (I don't normally like mixing oils for a full OCI) and the time to drain my oil, add the 3 qts, go on a 20 mile 70MPH highway drive, and dump that oil prior to putting in my "real" oil.
A couple of things I found interesting:
-the 20 mile oil drained out looking far dirtier than I expected (though it still looked pretty clean on the dipstick). It was not at all translucent in the drain pan.
-the "real" oil I put in afterward was the cleanest looking oil I've ever seen on my dipstick since the car was new. Could not even see it on the dipstick and when I wiped the dipstick with a paper towel, there was not even a hint of dirt left on the towel. It just looked like I squeezed a little bit of sewing machine oil on the paper towel.
I will probably only do this when this situation arises again, where I have just enough leftovers and plenty of time to do two drain and fills. Why not? Even if it doesn't really help anything, it's not hurting anything either.
For the record, the car was an 03 Civic with a 3.5qt capacity. 3 qts gets it to about the midpoint between the high and low marks on the dipstick. The leftover flush consisted of Castrol 0W40, Mobil 1 Extended Performance 0w20, Super Tech High Mileage FS 0W20/5W20, and a little bit of Pennzoil conventional 5W30. The "real" oil I ended with was Mobil 1 Advanced Fuel Economy 0W30.
No you won't... LOLI don't have to justify anything here, guys. Just sharing an experience. Next time I'll just keep it to myself. LOL.
WAIT! WAIT!????? What? You mean my crankcase has multiple brands of oil from all the times I switched brands? OMG my heads going to explode...&%&I^Huge waste of time and resources. You realize there’s a good amount of residual oil left in the internals, right? So you’ll always have a “frankenbrew” effect. Now even moreso since you added 4 more oils that are now part of the residual.
Not if you post about it on a public forum. That activity accomplished nothing, so how is it not a waste?Don't you think that is up to me to decide?
You are entitled to your opinion.Not if you post about it on a public forum. That activity accomplished nothing, so how is it not a waste?
I agree, i also think it is legit, but given the hellish weather where I am , I loathe jacking up and going under the car too soon to change the oil yet again. I will pass.For all the critics, I think this is legit. Minor cost in the grand scheme, and the oil did get used and serve a purpose; that was to help further clean and "reset" the engine internals to a far cleaner state. I'm a frugal person but not cheap and this seems like a good investment in time/resources for the OPs situation of extra resources (franken-oil and time).
OP wasn't going to use the oil for a full OCI anyway, so it was his purgative purogative.
Sure, he could have done a longer "short OCI" of say, 1000 miles or a month, etc, but sometimes we have to balance our time versus costs. He say he had the parts and time to do it, so on the balance sheet it may not have been a waste since he accomplished his goal of cleaning his engine. That's the point, afterall.
The main reason I did this when I did because the temperature was in the 50s, which is unseasonably warm for this time of year. I didn't think I'd have another opportunity for a long while.I agree, i also think it is legit, but given the hellish weather where I am , I loathe jacking up and going under the car too soon to change the oil yet again. I will pass.
