So this isn't something I plan on doing often, but the circumstances all came together to make it doable. I had just enough leftover oil of various brands and grades (3 qts) that I didn't have a use for (I don't normally like mixing oils for a full OCI) and the time to drain my oil, add the 3 qts, go on a 20 mile 70MPH highway drive, and dump that oil prior to putting in my "real" oil.
A couple of things I found interesting:
-the 20 mile oil drained out looking far dirtier than I expected (though it still looked pretty clean on the dipstick). It was not at all translucent in the drain pan.
-the "real" oil I put in afterward was the cleanest looking oil I've ever seen on my dipstick since the car was new. Could not even see it on the dipstick and when I wiped the dipstick with a paper towel, there was not even a hint of dirt left on the towel. It just looked like I squeezed a little bit of sewing machine oil on the paper towel.
I will probably only do this when this situation arises again, where I have just enough leftovers and plenty of time to do two drain and fills. Why not? Even if it doesn't really help anything, it's not hurting anything either.
For the record, the car was an 03 Civic with a 3.5qt capacity. 3 qts gets it to about the midpoint between the high and low marks on the dipstick. The leftover flush consisted of Castrol 0W40, M1 EP 0W20, ST HM FS 0W20/5W20, and a little bit of Pennzoil conventional 5W30. The "real" oil I ended with was M1 AFE 0W30.
