Hi,
I own a 2015 Dodge Durango RT with 5.7 HEMI engine.
Two weeks ago, I decided to change the oil for the first time since I own this car (I bought it in may with 60'000 km and now it has 70'000 km).
I used a kn 2010 filter and some 5W20 synthetic oil.
As the manual says, I first poured 6,6 litres / 7 quarts of oil. Then I started the engine some minutes, stopped it, wait some minutes and checked level of oil : min mark on the dipstick on a flat surface.
I decided to add more oil until I reach the max mark on the dipstick, and at the end, I poured a total of 7,4 litres / 7,8 quarts for be exactly on the max...
The next day, I started to notice a burnt oil / rubber smell that was coming into the cabin when I was stopped with the engine on (red light, arriving in my garage, etc). The smell was also present from outside the car, coming from engine compartment.
I checked everything, but no evidence of leak. Oil filter and drain plug weren't leaking, no leak around engine, nothing seemed wrong...
After some research, I found that there was a TSB for 2014-2015 Durango with 5.7 engine because the dipstick is too short... The TSB (I attached it for info) says that if the dipstick number doesn't end by AD, it's the wrong one. And of course mine ends by AC... It explains why I had to put almost 8 quarts in my engine...
Now, I drained 0,6 litres / 0,65 quarts of my engine with a little pump. It means I still have about 6,8 litres / 7,15 quarts, so still a few more than recommended but such a small overfill shouldn't be problematic, and I didn't want to drain more as I also don't know the exact capacity of the KN filter and as my dipstick isn't working, I'm a bit blind for see if I have enough oil or not...
I drove about 150 km since I removed the oil excess and even if the burnt smell is less frequent and less intense (I don't smell it anymore in red lights or stops) it's still noticeable typically when I arrive and stop in a closed space like my garage...
My questions are :
- Will the smell eventually go away?
- As I drove 10 days / 560km before removing the oil excess, could this have damaged my engine?
- When I removed the oil excess, I noticed that, after only 560 km, my oil was already black and smelling burnt. Is it due to my overfill incident? Should I change already the oil?
Thanks for your help and Merry Christmas
My questions are :
