Kestas
Staff member
I wonder if corrosion isn't part of the mix on the surface. Corrosion would hold the sludge better. Test a spot with solvent and an old toothbrush.
Sand itself is horrible for wear.
That's not possible because he can't get the trike to a bike shop and they won't come out to his place. Lucky me.If he truly has money to throw away I think it's only fair that he pays someone to fix his stuff.
Scott
Oh sure. When he got the trike the chain was dry and he didn't lube it until I pointed out it was rusty. It was only a few weeks after he had received the trike that I saw the mess.I wonder if corrosion isn't part of the mix on the surface. Corrosion would hold the sludge better. Test a spot with solvent and an old toothbrush.
I can't get over that!This trike has the worst components. The brakes come with the cheapest Shimano-labeled (knockoffs?) handles and the calipers are unbranded garbage that take Shimano pads. There's no pad adjustment dial on either caliper. The cotter pins that held the pads in were so short they were barely long enough to be bent open. two one-quarter-inch longer cotter pins weren't in the budget. There's surface rust on every part that's not aluminum.
I'm not going anywhere near Sparky when it's wet. I try not to sneeze near this thing. The 48 Volt battery isn't even fused. The electronic control unit isn't fused. The electronics are not in a sealed box but only have a top cover. There's an electrician's bird's nest visibly exposed.Clean it with a pressure washer.
He has Parkinson's and that condition can also affect the mind.Why are you even looking at this POS? Is the owner handicapped or disadvantaged in some way and you feel obligated to help him? If so, I respect that but does it makes sense when he won't even help himself by taking your advice?
He is fortunate to have your help!He has Parkinson's and that condition can also affect the mind.
I also cleaned the chain, something he's physically not really able to do properly. Surprisingly, the chain is still okay I checked with a chain wear indicator tool. I expect he's mostly riding with a high amount of pedal assist.Not my trike. This is an E-trike that is operated in a marine environment with sand, salt water spray, constantly changing temperatures, and often high humidity. This trike is only ten months old. I explained the different types of chain lubricants and the owner opted for motor oil anyway. I also had told him to wipe the chain down after lubricating it. Clearly he never did that. Since he's disabled he can't access the derailleur. I found this mess when I changed the disc brake pads on his trike. I did clean up the derailleur which appears to be of poor quality. I don't want to know why there's so much pubic hair stuck in the goop. Just gross.
That's because he let the chain get rusty before he ever put lube on it. I gave him a bottle of boiled linseed oil for his rusting cargo basket. I think he may have put linseed oil on the chain at some point. I get a whiff of it when I get close to the chain. Linseed oil would explain the sludge. I told him it's not a lubricant.Actually looks like there is corrosion under the crap.
With all those crappy parts (brakes especially) I hope he isn't actually riding it at 37 MPH. That thing will roll like a tumbleweed if he ever takes a turn too quickly!It goes 37mph.....
I suspect he likes the idea of going out in a blaze of glory and in a jumble of cheap Chinese parts. The fork broke going uphill because it couldn't handle the torque the 750W motor provides. The electronic control unit overheated and died going uphill because there is no overheat protection. The mechanical brakes are undersized Shimano knockoffs and are barely passable on a level surface. The trike with its extra large battery weighs over 120 lbs, he weighs another 260 lbs. That's a baby rhino coming at you at probably over 40 mph downhill. Another problem with a trike like that is that you can't steer well at higher speeds. You can't lean on a trike.With all those crappy parts (brakes especially) I hope he isn't actually riding it at 37 MPH. That thing will roll like a tumbleweed if he ever takes a turn too quickly!
I'm only here for the video.......you can't steer well at higher speeds. You can't lean on a trike.
Yeah, a saint cursing like a sailor.What a hassle. You are a saint.
