Not my trike. This is an E-trike that is operated in a marine environment with sand, salt water spray, constantly changing temperatures, and often high humidity. This trike is only ten months old. I explained the different types of chain lubricants and the owner opted for motor oil anyway. I also had told him to wipe the chain down after lubricating it. Clearly he never did that. Since he's disabled he can't access the derailleur. I found this mess when I changed the disc brake pads on his trike. I did clean up the derailleur which appears to be of poor quality. I don't want to know why there's so much pubic hair stuck in the goop. Just gross.
