Truth matters, right?
I would like to think so but experience shows me differently in this day and age.
Ultimately it depends on individual values and taking pride in one's efforts. I also believe it is critical to success.I would like to think so but experience shows me differently in this day and age.
You probably just have unrealistic expectations. At lower wage rates, you won't get a quality job. That's why it's common when an order gets screwed up at a fast food place. What do you expect for minimum wage? The manager is probably just making a few dollars more than the worker. You just have to be happy the wheel didn't fall off and got yourself killed on the way home. That's the type of pays your money and takes your chances world we live in.It's not a question; I already know. If I can't do the job or need more time it is my responsibility to say so.
That's how I get paid what I get paid. Truth matters, right?
I don't think techs get paid that much even when the dealer is charging $120/hour. One mechanic I use told me he got around $20-$25 an hour working at the dealer. I think he made up for it by getting paid for the hours that get billed so if he gets a 4 hour job done in 2, he can pocket that 2 hours that he'd be paid. Otherwise if it's just guys making minimum at the oil and tires, then no matter how you train them, they probably forget or they're not very good or they don't stick around long enough for it to sink in. I think on the flip side, if you take longer, you lose money so using a torque wrench would take longer and you'd lose money.True, but here all the dealer mechanics are union so if all the mechanics were all certified and the dealer is charging $120/hour so why wouldn't they do the work properly like they were taught? I've caught my dealer on several things before where things are missing or I've had to drive it straight back after I got home. Luckily I had another means of transportation otherwise I'd been out of a vehicle to go to work for another day or two.
EDIT: I'd like to add that yes some dealers do have lube techs that do the most menial job of oil changes and tire rotations but it's like "tight is tight" is a motto. At the BMW dealer I used to work for, some certified techs used torque wrenches on the wheel, some didn't. Not sure why there isn't an SOP for it.
I see your point. We are, however, talking about properly installing wheels on a car. Done incorrectly, this could lead to a deadly situation. Also, my point is, if I pay the agreed amount, the shop (dealor or indie) needs to do their part. Just my 2 cents.You probably just have unrealistic expectations. At lower wage rates, you won't get a quality job. That's why it's common when an order gets screwed up at a fast food place. What do you expect for minimum wage? The manager is probably just making a few dollars more than the worker. You just have to be happy the wheel didn't fall off and got yourself killed on the way home. That's the type of pays your money and takes your chances world we live in.
The really scary part of this is that no one will be surprised. There was a time when you payed more at the dealer for factory trained techs and work to spec. That was a long time ago now.
Well if they blast it on with an impact, there will be no issues of the wheel falling off. You just end up with other issues. All in the name of speed and money. There are consequences to the race to the bottom.I see your point. We are, however, talking about properly installing wheels on a car. Done incorrectly, this could lead to a deadly situation. Also, my point is, if I pay the agreed amount, the shop (dealor or indie) needs to do their part. Just my 2 cents.
Strip threads, distort rotors, damage wheels, break studs. Yes, the wheel can fall off.Well if they blast it on with an impact, there will be no issues of the wheel falling off. You just end up with other issues. All in the name of speed and money. There are consequences to the race to the bottom.
Well we were talking about incompetents. Better for them to overtighten and risk those than not tightening at all. At least that's probably how the shops see it. .Strip threads, distort rotors, damage wheels, break studs. Yes, the wheel can fall off.
For me, that's unacceptable. It's better to do it right; that's what I pay for. Clicking a torque wrench is not an advanced skill.Well we were talking about incompetents. Better for them to overtighten and risk those than not tightening at all. At least that's probably how the shops see it. .
You shouldn't need a 1" unless you work on dump trucks or heavy equipment.Ford truck? On a new to me F150 I had to use this arrangement to remove them from one wheel.
That's a 4 foot long 1 inch drive breaker bar with an even longer cheater pipe. Just getting the 25 pounds of metal on the lug nut was the hardest part. It was right after that, that I bought a 1" drive impact wrench. Also 25 pounds but much easier to maneuver.
Or it's a bad impact wrench.
Bought the 1" impact AFTER going through that ordeal.
