- Joined
- Jul 17, 2025
- Messages
- 35
Having the usual "brake job' tire repair/replacement, anything that requires the wheels coming off" problems with over-zealous "mechanics" with impact guns. Try to retorque lugs when I get home, but I live in NYC and it's kind of cold for driveway work, and sometimes you can't even get the lugs off without a major effort. Last visit I have a long conversation with the owner- "lugs nuts to 76 lbs", but made the mistake of telling him that I retorque them myself. He says "ok so just retorque them after we put them on". Pick up the car and ask the mechanic about the 76 pounds (note on the dash, notwithstanding) he says: "oh they're good and tight-I'll make them tighter if you want." I say no, they're supposed to be 76 pounds, and he points to the air valve and says : "76 pounds in the tire?" So my question is: does it matter "bolt stretch wise" if you pull them apart right after you get home, or leave them be for two months or so, and then redo them? Does the bolt stretch take a set so that it becomes "too late to rectify"?
