I have the VIOFO A129 Duo front/rear cameras in mine and her car. I had. VIOFO a119 for years and just wanted a rear camera just to have it, the 119 doesn’t support a rear camera so had to get a different model.
119 in her car and she wanted a rear camera because I got one so upgraded her as well. My old 119 is a backup if something were to go wrong with my 129, her 119 went in her daughters jeep
I have mine hardwired to fuse box, hers I had an OBD power cable powering her old one so I used that. They are recording continuously but go into parking mode when ignition is shut off. I’ve never had my battery run down. Most hardwire kits have a setting where you can set it if the battery reaches a Certain voltage it will turn off the camera to preserve your battery. I had my car parked at my buddies house that lives 5 minutes from the airport for 10 days and my car started fine when I got back.
Dash cams are basically to avoid he said/she said situations and for peace of mind. Instead of your word against theirs, you have undeniable proof of what happened.
There are so many brands out there. VIOFO, , Rexing, Blackvue ( really wanted to try one of those but more expensive and VIOFO does the same thing), Thinkware ($$$), Rove,Garmin, etc….and they all basically do the same thing. Some better than others.
Is a rear camera needed? As you said, black/white. If you are at a stop sign or stop light and all of a sudden your car gets rear ended, your front facing camera will clearly show the bump from behind and the damage on your rear end will make it obvious what happened. I went probably 10 years with just a front facing camera and was fine with that. I just wanted a rear camera just to have one. So I don’t think it is absolutely necessary. It can pick up an accident or whatever behind you and you could give that to the parties involved if you wanted too.
Thankfully I have never had an accident while I have had my camera (s) but I would rather have it than not have it. Just for the peace of mind
