The general rationale is described in the first link and the second link explains in detail the components of the dampers. It should be an easy conceptual exercise to get a rough idea how wear to bushings, seals, valves, guides, oil, etc. could produce a decrease in damping force or some kind of unwanted motion.I looked at both links. Link #2 is, I think irrelevant to the discussed matter and link #1 (tirereview) is just a bulletin post that repeats “every 50k miles” thesis, but does not explain how a unit that doesn’t leak and does not produce an extra bounce going over a bump can still be a spent one. So, can you explain it in your own words? Because I understand people that say: “no leaking and no extra bounce, therefore my dampers are fine”, but I don’t understand (hence my asking) people’s logic that say: “dampers that don’t leak and don’t produce extra bounce can still be spent”. If I understood correctly, you are in the 2nd camp, so I’m asking if you could explain the mechanics involved that substantiate your claim. If you don’t want to answer - it’s all good, but please don’t get offended like the other guy
BTW - I said this already - they absolutely DO produce extra "bounce". You just might not always notice it. Put a high res high sample rate accelerometer in the car and log data, then replace the shocks and do it again. You are going to have less motion.
