The Sachs dampers on my Tiguan lasted a little over 100,000 miles, then switched to Bilstein.
iirc, Bilstein is a supplier to Mercedes.
Could you please quantify it?
Leak.Did they leak or what happened?
That's why i replace them IF they fail the dyno test at yearly inspection. Inspection is statutory in my country.They might not be unsafe, but there is no way they work as well as new. I’ve never encountered dampers that didn’t feel tired compared to their replacements, and I’ve replaced them as early as 50k on some cars. It creeps up on you, but if you put them on a damper dyno I’m sure it’s not the same as new.
High end dampers need rebuilding quite often if you want to maintain performance.
I mean a real shock/damper dyno though like a performance shop would do. Not something you'll get at inspection. I'm sure they are safe, it's just I doubt they perform like new.That's why i replace them IF they fail the dyno test at yearly inspection. Inspection is statutory in my country.
its a dyno, same goes for brakes.I mean a real shock/damper dyno though like a performance shop would do. Not something you'll get at inspection.
Could be wrong, but all high resolution shock dynos I have seen require removal from the car.Finnish standards are like science fiction for many Americans![]()
They are testing to ensure safety. They are not testing to ensure OEM as-new performance. This is common sense.What’s the scoop on dampers lasting in Finland, given annual proper testing? Like what “do you hear” from friends and family on the matter?
*Congrats on joint NATO and thanks for your help to “friends-in-unhappiness” with respect to having a certain common neighbor![]()
HahhaFinnish standards are like science fiction for many Americans![]()
dyno test it is, maybe not high end test. But to measure the oem specs you must surely remove them. But it is perhaps a bit of an exaggeration when most of them are completely ordinary carsThey are testing to ensure safety. They are not testing to ensure OEM as-new performance. This is common sense.
Hahhayou get whipped for owning a car in Finland, would prefer to have American standards when it comes to cars
In my experience shocks with 100k are tired and it’s extremely noticeable when they are replaced.Is not sufficient for our purposes? An engine with a 100k miles on it is not to OEM spec either, but theres hardly a meaningful difference between them - for our purposes
I think most shocks and struts are replaced unnecessarily. I have found that in the absence of severe fluid leakage or obvious signs of failure, replacing the unit often yields very minimal improvements.
More often than not, folks replace the OE unit with an aftermarket unit that is tuned differently. The aftermarket unit is tuned to be stiffer (or softer), and because the driver notices a difference (after the work is done), they assume that the OE unit had failed.
